-   -   If you can't fill up becuase the gas pump handle keeps clicking... (http://www.dfw50s.com/showthread.php?t=4301)
Rydawg1 06-25-2014 05:59 PM
In the future, if any of you have an issue with the inability to fill up your car because the gas pump handle keeps clicking every time you squeeze it. I'd wager this is why. You've melted the vent hose. It's located right above the passenger side exhaust (the over axle part). I looked on the internet for information on this hose and didn't find a whole lot. So I figured this might save some of you the headache of looking for it.
The replacement part is about $150.00 bucks from the stealership or Tasca has it for $55. It can be swapped out relatively quickly by 3 quick connect clips. The part number for a 13-14 GT(I can only assume 11-12's are the same) is "DR3Z-9E325-A".
http://i172.photobucket.com/albums/w...psfab0ad0a.jpg
rlhay2 06-25-2014 10:18 PM
This is also the reason you may get "Check Gas Cap" or EVAP errors.
