Ice mode
Anybody know the ins and outs of ice mode?
Went into it 3 times yesterday @ BMW autocross (TMS bus lot=slick and slide able ). Kind of a fun sucker and a big driving distraction. Running with full TC/stab control turned off, yet it dropped into ice mode 3 times. Fellow competitor with same car (14 track pack) had the same issue. I'd like to know what triggers it,if it's something I can avoid with a driving style or what it would take to prevent. |
What's ice mode?
I have a V6 base but I've experienced this more with TRaction Control off and Stability Control on. Though I have had it happen with everything off, too. Apparently is has everything to do with the ABS. TMS Bus Lot is really slippery so if you brake exceptionally hard and start to slide, the car thinks you are on Ice. Apparently The intervals at which ABS brakes stop the wheel are way too fast for ice conditions so the ABS tried to compensate. I've also experienced it AFTER an AutoX when on the drive home. Kinda odd... But maybe the system is still "worried"
http://www.sccaforums.com/forums/aft/392890 I don't think there is anything we can do about it other than brake sooner :/ |
I think it also reengages some TC or stability control. It jumped in HARD, chirping the tires a couple of times when I was accellerating hard and had a nice drift going. Might be some cumulative triggers in the background. I've done 10-11 autocross with this car now, and its only happened during the 2 "hot lap" style events (NTAX, BMW). Pretty sure the surface is a contributor. 1st time was COLD (NTAX winter = sub 40), and Saturday was a slick sealed asphalt surface. I've gotten some other feedback similar to Ninja, i.e. try to be less aggressive on the brakes on these surfaces to try and keep it from engaging. |
Talk with Terry Fair. He may know something about it. I know some people have went and bought the Boss 302R/S ABS module that I think is supposed to eliminate this problem.
| All times are GMT -4. The time now is 03:13 AM. |
