-   -   Exahust leak fixed! (http://www.dfw50s.com/showthread.php?t=4873)
Taimigrrl87 04-07-2015 07:07 PM
Exahust leak fixed!
Turns out that after 3 shops, the 4th one actually knew what the fuck they were talking about. I kept getting told 'blown doughnut gasket' and when I went to order said part from Ford, turns out the v6 models don't have that, because it's built in. 4th shop found out that I had a cracked header on the right side, and replaced it for just under $500. Voila, no more vacuum issue(wasn't ever a vacuum issue, dude just didn't know what he was talking about)
While they were under the hood, they determined I have leaky valve cover gaskets, not a rear main seal leak, so that is next on the 'items to fix list'
I am very, very lucky that no damage was done to the engine running around on a cracked header(the pipe vibrated loose from the inner curve of the connecting flange, so still a leak, but not as bad) And suddenly, I have power that I didn't even realize I was missing, and the car doesn't sound like unholy hell and rattly.
Lucky13 04-07-2015 07:19 PM
Nice. Hopefully you didn't pay or can get your diag $$ back from the other 3 douche lords.
Taimigrrl87 04-07-2015 07:45 PM
Didn't have to pay for the other 3. I would advise to steer clear of McDavid Ford on White Settlement Road. The Service tech didn't bother to latch my hood and I was more excited to drive the car and get gone than I was to actually check that it was indeed shut, and had to jerk over to the shoulder after I noticed my hood bouncing. That is not something you want going 65 down 820!
NAVAG 04-07-2015 08:51 PM
Sadly, this is how a lot of shops operate. Surprised they didn't offer to rotate the air in your tires or a low rate.
Taimigrrl87 04-08-2015 07:30 PM
LOL! I'm female, not stupid.
