Alignment 04 Cobra / Frisco Area
Good afternoon,
I recently purchased a 04 Cobra that is in dire need of an alignment. I went to Firestone but the mechanic was using a monkey wrench and tried to jack up my rearend on the IRS subframe, so I politely asked to remove my car from the lift that I would be taking my car else where for a proper, non destructive maintenance alignment. I'm worried that most "mechanics" will not know the proper way to adjust the rear end and I'm not comfortable with jacking up the front end on the A-Arms either, Firestone has also tried that in the past. What shop or who would you guys suggest for a proper alignment on my 04 Cobra? Thanks, -A |
Dallas Frame and Alignment on Fabens Rd is the only place that aligned my SN95 with IRS swap.
| All times are GMT -4. The time now is 10:26 PM. |
