-   -   Best recommended Anti-freeze coolant (http://www.dfw50s.com/showthread.php?t=5090)
14s197 07-06-2016 12:37 AM
What is the best recommended Anti-freeze coolant to put in my 2014 Gt Track pack with the Boss 302 Radiator? What do you all suggest? I live in Texas, so it is pretty darn hot out here! Thanks in advance!
MyLilPony 08-01-2016 06:23 PM
Distilled water only if you can protect it from ever freezing. I am running a mix more towards just distilled water to ford factory radiator fluid.
3RD HNK 10-15-2016 03:37 AM
Grab a couple gallons from ford and distilled water is key. Also try givin MMR a call (ask for Taylor) and look in to the head cooling mod. I have a high dollar snap on live time thermal imaging tool and you wouldn't imagine the heat that is released with it. Simple install
rangejon 05-11-2018 03:44 AM
I use Prestone 50/50 mix and have no issue so far.
