NTAXS Autocross #4, 7/16, TMS Bus Lot
DRIVERS MUST PRESENT A VALID DRIVERS LICENSE.
North Texas Autocross Series (NTAXS) Saturday, July 16 Texas Motor Speedway Bus Lot in Fort Worth, TX $50/driver entry fee. Pre-register at http://www.dlbracing.com starting July 1. No on-site registration. The event is limited to 65 drivers. Once the event reaches 65 drivers, you will have the option of joining the waiting list when you attempt to register on DLB Racing. If your entry from the waiting list is accepted, then you will receive an email with links to complete your registration and submit payment, but you must do so within the next 24 hours or the invitation will expire. Note that the invite will use the Eastern time zone. You get eight runs at NTAXS events, so you will make four runs in the AM session and four runs in the PM session, with a lunch break in between. 8 AM – 9 AM Check-in, Registration, and mandatory Tech Inspection (You must arrive in time to check in and pass tech inspection prior to 9 AM) 8:00 AM – 9:15 AM Course open for walking 9:00 AM Novice Meeting (mandatory if new to NTAXS events) 9:15 AM Drivers Meeting (mandatory for all) 9:30 AM First car out Car Classing is based on engine size: - Class 1/1R is for engines under 2.3 liters, except Honda S2000 and Lotus Elise/Exige. - Class 2/2R is for engines over 2.2 liters, but under 4.0 liters, plus Honda S2000. - Class 3/3R is for engines over 3.9 liters, plus Lotus Elise/Exige. - Class S2000 is only for Honda S2000 on street tires. - Class X/XR is an open class for any engine displacement and induction. Rotary engine multiplies displacement by 2.0. Usage of forced induction multiplies displacement by 1.5. (This is in addition to the rotary multiplier, if applicable.) Tires with a wear rating under 140 must use the R class. View the rules, refund policy, and additional information at http://www.ntaxs.com . Refunds will be granted until 3 PM (Central) on the day prior to the event. After 3 PM on the day prior to the event, there will be no refunds or credits. Contact at northtexasautocrossseries at yahoo dot com for more information. Find us on Facebook at http://www.facebook.com/ntaxs . |
| All times are GMT -4. The time now is 11:50 PM. |
