Add stance to your Mustang with Body Kit by Clinched Flares!
If you want to customize your Mustang and fit it with a set of trending overfenders, you can easily achieve this goal with help of a new Wide Body Kit from Clinched Flares. Made out of ABS plastic utilizing CNC-cut molds to ensure a top quality fit and finish, it looks like a proper blend between a race and a street car. This kit not only changes the appearance of your Mustang but also improves it's performance capability since it allows you to run a much more aggressive wheel and tire combo. Clinched Flares® - Wide Body Kit (Unpainted) https://www.carid.com/images/for-for...kit-must-2.jpg https://www.carid.com/images/for-for...kit-must-1.jpg https://www.carid.com/images/for-for...kit-must-3.jpg https://www.carid.com/images/for-for...kit-must-4.jpg Features: - Includes: front and rear fender flares, front add-on lip, front bumper flares, side skirts - Impact-resistant construction won’t crack or peel - Built to ensure many years of faithful service - Allows you to run a much more aggressive wheel and tire combo thus helping you put all that mighty power to the ground - Constructed using industry-leading materials to ensure the highest endurance and longest lifespan - You will be required to cut your existing fenders and quarter panels - The kit does not come with mounting hardware or rubber gaskets (sold separately). Clinched Flares™ | Fender Flares, Body Kits, Hood Vents — CARiD.com https://www.carid.com/images/for-for...d-dealer-1.jpg What are your thoughts about this body kit? Let us know in the comment section below! |
