Oil leak
I guess i should start by saying this is an 89 gt with a 302. I have oil on the top of my block on the back side of my motor behind intake. It goes around the sides below the heads also. The only thing I can come up with is the rear main but I wouldn't think it would get oil up there so could it be from the heads. I know the oil pan gaskets leaks and that will be fixed this week but I just can't seem to figure out where the oil on top of the motor is coming from.
EGR still on the car?
Yes
No oil around it
Valve Cover gaskets
Edit, or PCV valve isnt in place, or gasket fell out... check the PCV system and your valve covers... if you have the old cork ones, throw them away and buy the later model metal and rubber gaskets. Those dont leak. |
[QUOTE=STROKD;11501]Valve Cover gaskets
Edit, or PCV valve isnt in place, or gasket fell out... check the PCV system and your valve covers... if you have the old cork ones, throw them away and buy the later model metal and rubber gaskets. Those dont leak.[/ The valve cover gasket on the passenger side is leaking but not in the back. The driver side is not leaking at all. I believe Sean at truestreetmotorsports checked the Pcv valve before dynoing the car a few weeks ago but I will check it again. |
Pcv valve is in but does look like it is leaking around it. Could have bad o-ring. I will pick up valve cover gaskets and new Pcv vale today to install this weekend. There is oil all over the top of the bell housing of the tranny. Not sure if these are the cause but I guess it's a start
I assume you have a valve cover breather? If not the pcv could just blow out under boost. Lol
the rear portion of the intake could not be sealed good.
Well took the car to a buddy of mine and she is all fixed up. The oil pan gasket and the Pcv valve were the problems. The Pcv valve was toast, the rubber deal was bad and there was no oil screen, that was leaking pretty bad. All other seals look good. Have one little leak because of the valve cover breather but I will need new valve covers to fix. But I fixed my hood so now I have the clearance to do it. Now I don't have to replace my hood, lots of money saved right there.
| All times are GMT -4. The time now is 10:22 PM. |
