Old 08-22-2013, 12:49 AM   #121
downtime!
downtime!'s Avatar
Stock tire size on my '12 was nearly 28" tall. I run 295/55's which are about the same height as stock. Car came equipped with 3.55's from the factory. I cross the traps at 7200 in 4th (MT82). 28" works quite well with 3.55's.
Old 08-22-2013, 10:10 AM   #122
Doug1227
Mine was shifting into 4th right before the finish line with my 3.15's. It short shifted at 7000. I think I can avoid this shift all together if I just raise the 3-4 shift point. This SHOULD cut some ET as well since I'm removing a shift. Right? Not sure how much though.
2012 GT/CS KB2.8LC 596/487
Doug1227 is offline   Reply With Quote
Old 08-22-2013, 10:19 AM   #123
STROKD
Old School
Solid point, but you are also going 130+, he does like 114... He would be MUCH lower in the powerband thus killing his time. I think he should get some 26 inch tires personally so it's as close to redline in fourth as possible.
86 GT 374 Billet "W" w/ 72MMs
Old 08-22-2013, 10:43 AM   #124
Junkie
Junkie's Avatar
28" tire and just make more power.
My daily is faster then your race car
Junkie is offline   Reply With Quote
Old 08-22-2013, 10:49 AM   #125
Assuming my redline is set to 7200 RPM, in 4th gear (1.32:1) with 3.55s and a 27" tire, I'll be turning around 123-124 MPH.
A 26" tire would basically give me 118-119 MPH at 7200 RPM redline
I think a 26" tire height is my best bet for the power level I will have my car at for a long while before boost. I should never trap more than 118-119 if I'm around 420-430 rwhp (after E85 conversion and maybe a TB). Right?
Old 08-22-2013, 11:11 AM   #126
46Tbird
46Tbird's Avatar
I'm right at the stock rev limiter in fourth gear when crossing the quarter mile.
3.73s
28.5" tall tire (305/35-20)
114.5mph
I dunno about you, but I would expect at least that kinda trap for a modded coyote...
Old 08-22-2013, 11:16 AM   #127
wbt
You will want to give yourself a little cushion. Peak power with the stock intake is going to be around 6,500. 118 with a 27" tire and 3.55 is ~6,900.
wbt is offline   Reply With Quote
Old 08-22-2013, 11:37 AM   #128
3.73s
114.5mph
Brent is/was trapping around 118 with his setup consisting of Boss IM, and all those other goodies. I would think I would be slightly below that, but I don't mind going with a 27" tire at all. Actually, that would be nice to drive to the track on a tire setup that wasn't 1" shorter OD in the rear. LOL
But yes, in perfect math/conditions, a 27" tire would but me basically at 120 at 7000 RPM. 120 MPH should be a low-mid 11 sec pass, correct?
Old 08-22-2013, 12:06 PM   #129
downtime!
downtime!'s Avatar
Mine has crossed the line at 7200 since day one, naturally aspirated at 115 mph and blown at 130 mph. Gearing is gearing.
Old 08-22-2013, 12:07 PM   #130
wbt
Yes all things considered.
Old 08-22-2013, 12:07 PM   #131
downtime!
downtime!'s Avatar
My best n/a pass was 11.67 @ 119, so yep, pretty close.
Old 08-22-2013, 12:19 PM   #132
46Tbird
46Tbird's Avatar
If you're buying a dedicated drag wheel/tire setup, get the 28s. They will work fine with your n/a combo and give you room to grow.
Old 08-22-2013, 12:47 PM   #133
You're right. It doesn't hurt to give room for growth. Plus when I go boost in years down the road and swap to 3.31s, that will help prevent me from going into 5th hopefully...
Old 08-22-2013, 09:01 PM   #134
Oxford14Stang
Oxford14Stang's Avatar
It doesn't really matter. We're all slow.
2014 Oxford White 5.0 MT-82
Oxford14Stang is offline   Reply With Quote
Old 08-23-2013, 12:58 AM   #135
STROKD
Old School
soundsa bout right... also, the Quick Times are bias ply, they grow about an inch when they are wound up, so you can prob go closer to 122... Absolute WORST case after you have the tires, bump the revlimiter 100-200 rpm if you are tagging it. Those motors will spin to the moon and not g.a.f.
