Old 04-08-2013, 10:29 PM   #16
KnightRider5.0
KnightRider5.0's Avatar
Default My future build plans, please post thoughts and ideas about it
Well sounds like shocks and struts are in order to be changed then. Am I going to need a new alignment after swapping and adjusting those with the new larger tires and wheels? All your advice has been greatly appreciated.
KnightRider5.0 is offline   Reply With Quote
Old 04-08-2013, 10:51 PM   #17
CMORENO302
CMORENO302's Avatar
Originally Posted by 46Tbird View Post
I guess it's a good list, but since we have no real idea what you intend to do with the car, it's kinda tough to say if the list is appropriate or not.
If you're wanting .02 worth of opinion, here ya go.
I don't understand the point of a "throttle body spacer." Sounds like something that will cause intake tube fitment issues and possible leaks for little or zero gain.
The Invos suck. They have an interesting tread pattern but they're hard as a rock and have terrible traction in any/all conditions. They are cheap and that might be the reason you've chosen them, but there are a lot better tires out there, even for the same money (Nitto NT555 and Continental Extreme) or more expensive (Toyo Proxes and Michelin Super Sport).
The reason your Sportlines are 'rough' is because of the matched shocks and struts from Eibach. I suggest an adjustable set of shocks/struts so you can make the car as stiff as appropriate. I have Sportlines with Tokico D-specs, and right now I have them set at 1 turn in the front and 3 in the rear (adjustable from 0 turns soft to 7 turns firm) and it rides like a Cadillac. I can crank them down to teeth-rattle in about two minutes total.
All the Ford parts are okay. All of them you listed are repackaged versions of other aftermarket parts, so it's hard to go wrong there.
You did ask...
Tokico D-specs are good to go? I was planning in buying the eibach kit. Just want a smoother ride and tighter suspension.
2013 MUSTANG 5.0 PERFORMANCE WHITE
CMORENO302 is offline   Reply With Quote
Old 04-08-2013, 11:09 PM   #18
Get the Tokicos, or any adjustable strut/shock combo. You will thank yourself later
Old 04-08-2013, 11:11 PM   #19
46Tbird
46Tbird's Avatar
Yes, you really need to align your car after replacing any front end parts.
I like mine, but they're just what I was able to find Used for a good price. The Koni Yellows are just as good. There are also some nice options in coilovers.
Old 04-08-2013, 11:33 PM   #20
Toby
If you can't see the pic
It's
DSS aluminum drive shaft Go with a dynotech
Ford P series lowering springs my sport lines are getting rough. H&R race springs
AMR Staggered Black 20X9 and 20X10 with nitto invos
Ford Racing Panhard BMR is the only brand I will recommend. I have installed dozens of both and the ford racing i dislike as I do the steeda.
Ford Racing Short Throw Shifter MGW FTMFW!
Throttle body spacer Dont waste your money those are a joke
Blacked out Side-markers[/IMG][/IMG]
See the red^^^
Also as mentioned invest in a set of koni yellow's. With that you can adjust the soft and firm settings to your liking. Not to mention the rebound valving is far superior to the eibach junk that is on there.
Old 04-09-2013, 06:58 AM   #21
pohnjarker
just my opinion...
honestly, unless you're going FI, you dont really need a aluminum drive shaft, but if you want one, id go with the dynotech drive shaft
Ultralite Springs on some Tokicos or Koni Yellows....i went with the 10 way adjustable Strange shocks/struts.
BMR or Whiteline adjustable panhard
Barton will save you a couple hundred and is said to be a step below the MGW. Barton makes the Ford shifter and charges less. i got mine for 250 used, looking forward to putting it on.
Throttle body spacer is a waste of time.
I also agree the Invos suck, you can do much better like 46Tbird said.
what other mods do you have?
Old 04-09-2013, 07:40 AM   #22
KnightRider5.0
Right now full eibach sport package front sway, rear sway, tower strut brace are all eibach, Roush cold air intake, roush axle back, The brembo brake package, A ford performance tune. halo center fogs but its hard to get a good picture of them. I've got a bmr driveshaft loop I got from a part out, yet to be installed.
Old 04-09-2013, 10:51 AM   #23
merlinmol
merlinmol's Avatar
Na my car has the full eibach sport line package to include struts and springs it's like a $1,300 kit and I have had the suspension checked out the shocks and struts are fine. They guy who owned the car before me had the dealership I bought the car from install the eibach package. And ford for undisclosed reasons
I feel bad that they charge $1300 for this, you can get a couple different coil over sets for around $1000.
2002 Camaro SS M6 (Daily)
Dynocom SEMA Video w/ Car
merlinmol is offline   Reply With Quote
Old 04-09-2013, 11:00 AM   #24
KnightRider5.0
Didn't buy it previous owner
Old 04-09-2013, 01:23 PM   #25
pohnjarker
thats what i like about forums, you get to talk to more people than just a salesman trying to sell you something.
Old 04-09-2013, 09:51 PM   #26
KnightRider5.0
I know it's a debate but driveshafts DSS? Or Dynotech?
Old 04-10-2013, 03:12 PM   #27
zemog255
zemog255's Avatar
Why do you want a different drive shaft? They aren't cheap and the gains are minimal. All it is stronger and you don't seem to have any straight line performance mods.
2013 5.0 A6:
zemog255 is offline   Reply With Quote
Old 04-10-2013, 04:06 PM   #28
KnightRider5.0
You did ask...
I looked up both the Koni yellows an Tokico D specs and both say don't fit 2011+ mustangs only for 05-10 GTs. So is the fitment wrong on American muscle?
Old 04-10-2013, 04:30 PM   #29
pohnjarker
you can run the 05-10 with the GT500 strut mount or other like the steeda heavy duty strut mount or caster camber plates
Old 04-10-2013, 06:18 PM   #30
46Tbird
46Tbird's Avatar
Just as ^^ he said, all you need is a pair of GT500 strut mounts and you can install them on your car. You really want to have that better strut mount anyway, the '11+ design is absolute TRASH and they normally fall completely apart when you disassemble the front end.
