| General Discussions Discuss anything in general about your 5.0 Mustang that doesn't belong within the other categories here. |
| Sponsored Ads |
01-14-2013, 06:13 PM
This is getting good.
01-14-2013, 07:50 PM
Nick  you know your power goal is way above mine..
2008 C6 coupe BPU++ Tuned by sam.
01-14-2013, 07:58 PM
I know plenty of fast mustangs..im sure ronnie would drag me..
01-15-2013, 03:03 AM
Old School
Im not sure how, he doesnt make that much more power than you on kill and he makes less on his street setup... His car weighs more even though you have the heaviest C6 on the planet, you have a couple hundred lbs less weight to carry than he do.
Dave just down plays his car because he doesnt like to race anymore. If he does it might break and he's tired of it sitting at the shop.
86 GT 374 Billet "W" w/ 72MMs
01-14-2013, 08:10 PM
If I put 1/2 of what I put into the vette into the mustang it would run 8s.
Mustangs rock. My vette does make 2.5x the power the 5.0 does at the moment. Hopefully I can fix that soon enough.
01-15-2013, 09:39 AM
My Ysi is only hitting 11psi because of belt slip which sucks. I really want to see 15-16psi for my street setup. Still makes 905-915 depending on how much the belt slips on a run. Once I swap to a larger crank pulley hoping to pick up 3-4psi and a bit more power.
01-15-2013, 11:37 AM
Yeah.. Mine peAks at 18 i think... 10 rib with dP direct drive.. But very low timing conservative tune.. Not trying to break 1k.
01-15-2013, 02:39 PM
Time to man up.
01-15-2013, 02:55 PM
Lol
01-15-2013, 05:17 PM
Old School
do you have 8 or 10 rib? Crank pulley will help a lot, as does their sandblasted "renegade" pullies... Getting 20+ psi out of my dad's YSi on his Stang and it isnt even pullied that hard yet. Have a pulley waiting to go on it (if the fuel pump will support it) that should get it up to around 26 psi.
01-15-2013, 06:30 PM
8 rib and direct drive. Currently 2.85" upper and a 7.25" lower. Need to goto a 8.0"/3.15". Elevation also kills boost, and my heads are huge so that lowers boost. They flow 410+cfm and I have a big nasty cam. With stock heads/cam it would be 20+ easy.
01-15-2013, 08:24 PM
which heads do you have? my heads are pretty decent but i have a mild cam..
01-15-2013, 08:40 PM
#13
Old School
410 is sick, thats like race car heads for a Mustang...
an 8 lower with a 3 upper will make a huge smile on your face... should be around 18-20 psi Id think. I was making about 27 psi with that setup on my 408 about 10 years ago.
01-15-2013, 09:47 PM
#14
race car shit...
i have a 4" upper and some street car heads
01-15-2013, 09:57 PM
#15
Prochargers have a bigger stepup so a 4.0" PC pulley is like a 3.0" vortech. Your heads are almost the same as mine. Street car stuff
