Go Back   Dallas Fort Worth 5.0 Mustang Club > Sponsors and Vendors > Vorshlag Motorsports
Old 08-16-2013, 01:37 PM   #11
Fair
Project Update for July 6, 2011: Lots of little things going on with our Mustang since the last post. Apologies in advance for the pictures - I left my Nikon at McCall's on Friday (working on his Z3 LS1) so I took all of these with my iPhone. Let me catch everyone up...
FCS1219311: 2011 MUSTANG WORKSHOP MANUAL @ $180.00/set
The 2 volume Helms Ford Factory Manuals were finally printed for the 2011 Mustang, and we got ours last week. Now we can hopefully find all of the little fixes and tricks to maximize everything. I looked in the power steering section - zero diagnostics help.
As you can see above we have added some underhood silliness, above... I'm normally not one for "bling" but most of this round of mods has a purpose.
I'm sure the blue coil covers will get some "ricer!" grief, but oh well. So I started by removing the coil covers (they pop off in seconds), then cleaned them with soap/water, then wiped them with alcohol. Next came five sprayed on coats of Rust-oleum "Ford Blue" high heat engine paint and then a couple of coats of Rust-oleum "High Performance Wheel Paint" clear coat. It was super easy to get these off and on, and only took about 30 minutes of work (plus drying time). This blue matches the 2012 Boss 302. Yea, its just flash, and all of the guys here at Vorshlag were hating on this mod, as was my wife Amy ("What next, a Superman cape?!"), but its an authentic tribute to the new Boss 302, so screw you guys!
Next up was the JLT oil separator catch can kit for the 2011-2012 5.0 and Boss 302. We picked the the "Passenger Side Kit" ($119) and it installs in literally seconds. Two squeezed clamps (which you can un-snap by hand) to remove the old vacuum tube, then the kit pops on in place - the hose from the intake to the passenger side valve cover. During high RPM use (and really the subsequent "high vacuum" period on engine deceleration) it will catch the oil vapors (separates and traps it in the catch can) instead of burning it inside the engine. I've seen guys track these 5.0s start pushing oil out into the air cleaner, but its usually people that live on the rev limiter. Last up is the Redline Tuning Gas Strut hood lift kit, which I also got from JLT. This simple to install $84 kit comes with all of the goodies to replace the stupid stock hood prop rod. If you park into the wind and leave the hood up (which we do often at the drag strip, road course events and autocross events) the hood can rattle and flop around, even fall off the prop rod. Now that we have real hood struts, these issues are resolved.
Last up, the video of the "Electronic steering shudder" feedback issue we've run into on our car:
This video describes what we're seeing and shows in in great detail. If you know anyone at Ford and would like to send them this link, please do! Also, anyone road racing the new Boss302S (with the same electric steering) - have you seen this?
We're not trying to blame Ford for a poor design, just want to find the sensor or broken wiring or whatever is causing this horrendous cyclical feedback in the steering. Its actually pretty dangerous... once it happens you have to pull over and almost come to a complete stop to get it to stop. And its getting worse; it happened to me yesterday twice, on the highway, going perfectly straight.
Yes, we might have inadvertently done something to cause this - I'm looking for the solution, and I'm willing to pay for new parts if its our fault. We've pulled out the "excessive" negative camber up front (that someone suggested as the cause), and zero'd the front toe, but so far nothing has fixed it. Any suggestions or "its happened to us too!" experiences are welcomed.
Thanks,
Former site sponsor
Fair is offline
