Old 03-15-2013, 12:52 PM   #1
FreddieG
Thanks for the suggestions. So many options on springs. I have 275/40/19 with the rtrs and stick out slightly so I dont want to go to low. I also don't have a whole lot front gap cause of the tire size. Will the struts with factory springs lower it any?
FreddieG is offline   Reply With Quote
Old 03-15-2013, 02:46 PM   #2
Courtesy Flush
Negative.
Struts and shocks will just adjust dampening and ride quality.
You will need a spring if you want height adjustment.
I run the K springs with a 275/40. They're not too bad. The rear springs could be stiffer IMO, but for daily and occasional track duty they get the job done as advertised.
Courtesy Flush is offline   Reply With Quote
