Old 06-14-2013, 06:20 PM   #1
RedRedemption
RedRedemption's Avatar
Default Gear whine on 3.73s
Hey guys I got some gears installed around February. Ever since I got them, there would be a gear whine when I deaccerlerated from 50mph-40. It doesnt make any other sounds other than just part of gear. Could anyone help me out and tell me what make it whine? I thought if I gave it a couple months so the gears could break in, it would go away? But I was wrong
RedRedemption is offline   Reply With Quote
Old 06-15-2013, 05:39 AM   #2
Luke
Luke's Avatar
What brand gears, who installed them, and did they use friction modifier
Luke is offline   Reply With Quote
Old 06-15-2013, 10:43 AM   #3
RedRedemption
I got them installed at TrueStreet. They used ford gears and I am pretty sure they used friction modifier?
Old 06-15-2013, 11:14 AM   #4
Luke
Luke's Avatar
Oh, well if it's TrueStreet just give them a shout on here, I'm sure they'll answer any questions you have.
Old 06-15-2013, 12:39 PM   #5
Toby
So it only does it decelerating from 50-40? is there a specific gear it does it in or any time any gear from 50-40 mph?
Btw yes we used ford friction modifier along with royal purple 75-90 gear oil in all of our gear installs.
Old 06-15-2013, 12:47 PM   #6
TrueStreetMotorSports.com
How soon can you bring it by for us to take a look at it?
Clint
True Street MotorSports
901 N McDonald St Suite 100
McKinney TX 75069
972.542.9886
TrueStreetMotorSports.com is offline   Reply With Quote
Old 06-15-2013, 02:56 PM   #7
RedRedemption
It only does it from 50-40. When I let off the gas between that speed, it will start whining. Its weird because im pretty sure its in last gear. But it doesnt whine when slowing down from 60-50 or etc.
Old 06-15-2013, 04:14 PM   #8
MidWest281
MidWest281's Avatar
sounds like a transmission problem, not a rear end gear problem. If it was a rear end gear issue, the whine would likely be present all the time.
2013 Performance White Boss 302
-Stock
2002 Mineral Gray GT
-VT engines Stage 2 N/A cams, full SLP exhaust, 4.10 gear...etc.
MidWest281 is offline   Reply With Quote
Old 06-15-2013, 04:28 PM   #9
RedRedemption
I don't think it would be a transmission problem because it didnt make any sounds or anything before the gear swap.
Old 06-17-2013, 04:09 PM   #10
kn7671
75w90 gear oil...? I'm pretty sure these cars call for 75w-140 gear oil specifically to quiet down the gear noises associated with 3.73 and numerically higher ratio's.
Also, some shops or mechanics will try to save themselves or customers money re-using the Inner Pinion Bearing and Race, and even sometimes the crush sleeve. I don't care if my car had 200-miles on it when getting a gear swap, a new Inner Pinion bearing is getting installed, regardless of the tools or confidence of the shop and/or mechanic. These few new additional parts cost only $75.00 at the most, and could be the difference between a happy or unhappy customer.
FYI - I have no knowledge of TrueStreet, their reputation, expertise on gear changes, or how they do anything. My comments are simply in reflection of my personal preference. I buy my own parts and watch the mechanic do the install, or it doesn't get done.
2015 Mustang GT - Black w/Perf Package
kn7671 is offline   Reply With Quote
Old 06-17-2013, 05:09 PM   #11
Toby
We have used 75-90 in every set of gears we install with 0 issues of noise. This is actually the first set of gears I have installed that I have been told about making any noise even as minor as this. Also with all new mustangs we always replace the inner pinion bearing with a new one. We keep at least 5 on them in stock.. Most of the time when you try and remove the inner bearing, the case that holds the bearings in place will either get damaged or stretched to where the bearings are now loose, thus the reason for replacing them. Also note that every set of ford racing gears include a new pinion nut and crush sleeve that MUST ALWAYS be replaced with any gear job regardless of any situation!
redredemption we will see you soon to get this guy torn apart to see what is going on!
Old 06-18-2013, 11:26 AM   #12
RedRedemption
Yeah Truestreet is awesome hopefully we can get it figured out this weekend!
