Go Back   Dallas Fort Worth 5.0 Mustang Club > Photos & Videos > Foxbody 5.0s
Foxbody 5.0s For the original 5.0s that started it all
Old 12-09-2013, 06:13 PM   #1
Originally Posted by blownaltered View Post
I know, I know. I did forget to attach the fact that combo is on a 363 not a 408. I'm also bored out of my fucking mind so I keep looking up shit. I'm just thinking a combo like that with less boost will put me where I want to be and if I ever wanted to turn it up I could.
If that was a 408 with bigger heads, itd be that power on like 17 psi.
I plan to make that on race gas at about 12, but im turning big rpm and have 2 turbos similar in size.
Old 12-12-2013, 08:33 PM   #2
Trust me I know where your coming from but I have no desire to try and compete with guys running 1000hp. That's not what I'm into. Once upon a time I would have spent money to try and get there but I just want a certain power level and I will be fine. I know the 408 will make it easier but I would have to change to much stuff that I don't want to have to change.
I plan to make a plan to build both and see where I end up price wise. Since huge horsepower isn't my end goal it will most likely come down to price. If the 408 is within a certain amount of the 347 then I will start purchasing parts for it but if it is a lot more then I will stick with the 347, make my 650 to 700 hp and be happy.
Old 12-12-2013, 09:15 PM   #3
It depends on what you plan to replace anyway. If you are changing the intake and headers, parts are same price for either motor... if all you need is a gd ac bracket, ill buy a new one and give you my old one. The biggest deal is the hood which you already have... if you dont want huge power, you can get a sportsman 9.5 deck block like i had for cheaper than a dart or boss block for a baby motor... the sportsman block will support 800 rw with no problems, 1000 rw with billet main caps.
I know you arent trying to make big power, but the 408 just makes more sense. If I could afford another build Id sell you my 351 shortstroke and go to a 427 in a heartbeat...
Old 12-13-2013, 02:01 PM   #4
So I've been reading a bunch today about the 351 swap and there isn't as many different parts as I thought. My water pump, timing cover and other misc parts are still good. I would definitely need bigger heads and a different intake but I was already looking at that. I thought I was going to have to change my kmember but I don't so that makes a huge difference in what I can do.
Old 12-13-2013, 02:13 PM   #5
Correct. You will need a new distributor and ac bracket, but heads, intake, headers etc you were upgrading anyway... nows the time to do it! That blower u have at 10 psi and pump should make 600 rw and have a ton of torque... dont know how much boost it will push but it will be easier to make good smooth power, and u can run a smaller cam so that makes it more driver friendly, and then u can run taller gears for better mpg too if u wanted...
Old 12-13-2013, 03:01 PM   #6
I actually have an msd distributor sitting on my shelf in the garage for a 351w. I have a vic jr intake but it is for a carb motor not efi, so I will sell that to get some money for they new intake. Hell I still have a 750 double pumper sitting on my shelf from one of my old 351w.
Old 12-13-2013, 03:06 PM   #7
If u go spyder style intake, u can use the one you have and have it converted. They drill holes and add the injector bungs and fuel rails attach to the bungs. This is how they are all done.
