08-16-2013, 01:31 PM
Mini-update May 20, 2011: Pictures DO say a thousands words. A buddy of ours (STX competitor and VTPP tester Brad Maxcy) took some great shots of the Mustang at the Divisional last weekend. He has an awesome camera/lens and is also not a total photo hack like me.
These close-ups show that the car looks pretty composed in most corners, well, at least when Amy is driving (when I'm behind the wheel its nothing but jackassery). Loaded up laterally like this it looks to be cornering pretty flat, outside front wheel still shows negative camber, and the inside front is just barely staying on the ground.
The outside rear wheel is definitely going into positive camber under load. We need to see what we can do about that. Could be all of the sloppy rubber bushings in the rear suspension all loading up....
More soon,
Former site sponsor
08-16-2013, 01:32 PM
Project Update for June 2, 2011: We dropped the Mustang off at True Street Motorsports in McKinney, TX today and they fixed all manner of things + diagnosed some other quirks we've run across. I finally found a good tuner shop (just 6 miles north of our location) that can custom dyno tune the 2011 GT via the SCT tuner we have, and they already have a great reputation. The owner of the shop also owns a 2011 Mustang 5.0 GT, which they've modded and tuned already.
Their tuning guru Sean Burt (who, as luck would have it, tuned our 7.0L Alpha car's new motor when it made 488 whp, back at LG Motorsports in 2009) started out by getting a baseline dyno run in the car with the existing custom tune + the Steeda cold air installed, which was 389 whp right at 5000 miles on the odometer. This compares to the initial dead-stock dyno pull (on the same style DynoJet 224) of 367 whp at 500 miles on the odometer (uncorrected it was 378 whp - it was a cold day) on Nov 18, 2010 (see bone stock dyno chart below).
This was the corrected bone stock dyno number at 500 miles back in Nov 2010 (uncorrected print-out is here)
I explained to Sean in painful detail what I wanted: more control, not necessarily more power. Probably one of their only customers asking for a custom tune but not wanting more peak power. I talked about tip-in throttle, falling rate vs rising rate throttle response, and the massive power-modulation issues we were having in 1st and 2nd gear, on corner exit in autocross events. I asked him to drive the car to see if he can feel the difference, before, during and after his tweaks.
After talking to some other local 2011 Mustang GT owners I was also curious why the car feels like it has a 200 pound flywheel. I made some calls earlier this week and according to the folks at Fidanza the OEM flywheel is only 21.5 lbs. They were the only place I called that had an answer - because they make a lighter 2011 GT aluminum flywheel (12 lbs) and had weighed the stock unit. We cannot use an aftermarket flywheel in STX, but I just wanted to know what the stock unit weighed to see if it would explain the sluggish nature of engine revving - it didn't.
This afternoon when I went to pick up the car Sean had a lot of great information for us, as well as two new tunes loaded to our SCT unit and three color print outs of the various dyno pulls. That seems trivial but when you pay for dyno tuning you sometimes have to ask for printouts. They even videoed the dyno pull. Great service! They are also familiar with HP Tuners and other software packages, and I noticed several LSx powered cars as well as an SRT Challenger in their shop for tuning that day.
They tinkered with our Mustang off and on for several hours, made some calls to some other SCT gurus, even to some folks at Ford. Here's what they relayed to me:
1. There is a very weird steering feedback issue we had noticed but didn't mention to him, as we thought it was just a bad wheel bearing (we already received a new pair to install, next). He brought this up after driving the car... the explanation he had was bizarre, but it makes perfect sense. Its possibly a programming issue (that he cannot alter), so once we test this theory to verify his conclusions I will post up about it. Don't want to spread bad information if this isn't the cause. Its something we've been noticing for a while, but had not mentioned here yet.
2. The "heavy flywheel effect" is all in ignition timing. The OEM tune adds 66 degrees of ignition advance in "engine deceleration mode" (off throttle, falling RPMs), which slows the engine responsiveness. He changed this to a normal 12 degrees and wow, what a difference. The engine response is SO much more lively! Its easier to rev match downshifts, too. I had no idea that could be in the programming.
3. Sean says they've used 7700-7800 rpm redlines in these new Coyote 5.0 engines without issue. Yikes! The dyno pulls show that the motor is starting to lose power above 6700 rpm, so it doesn't make sense to go to these stratospheric revs unless its in an autocross situation where we're barely touching those high revs, to avoid a 2-3-2 shift on a short straight. Anything we can do to avoid a lot of shifting is a win, especially after the last autocross (where I needed 4 separate 2-3-2 shifts per run!). We'll keep an eye on the harmonic balancer (check for slipping) and oil usage, but we've gone ahead and moved the redline on our car to 7700 rpm, up from our previous 7400 number, and way up from the stock 6800 redline. Zing! I'm already looking at aftermarket SFI rated balancers, for long term durability.
4. So last, but not least - the throttle mapping. Again, everything is all new on 2011s, as they can tune 2005-2010 throttle mapping easily. Sean tried to alter the correlation of pedal to throttle like I asked for, but there are something like 3 separate data tables/variables necessary to drive this interface, and he said if he altered all 3 the computer would "throw a wrench" error code on the dash. He says he has tried this on 2011s and it keeps "relearning around the tuning". He did try something very novel on our "track tune" and it might be effective - more than just running the car in a higher gear (our autocross testing showed Costas to be faster in 3rd gear rather than running in 2nd - which was such a kludge of a fix we'll try anything). Again, this tuning trick might be a flop so we're going to hold off on explaining about what he did until I can prove that it works. We will be testing the new tune at two autocross events this weekend. He loaded another identical tune without this throttle tricking tweak as our "street tune", which I can switch to in 90 seconds if the other doesn't work out. This "street tune" in fact makes more power... but again, we cannot use the power we're making in autocross situations, so this unusual "track tune" might indeed be faster.
Today's final 2 tunes with a peak number of 392 whp, corrected
So where are we now? 4500 miles later with one single bolt on part (cold air) and a custom tune we're at 392 whp, up +25 whp and +28 wtq on the new "street tune" over stock. That's pretty damn good power for an STX legal car with an air filter and "some 1s and 0s". A tiny part of the increase in peak numbers is the rise in the redline, as the bone stock dyno pull was just barely still going up at the stock 6800 rpm fuel cut. But the shape of both the new power and torque curves look nearly identical to stock, with the numbers up across the board, and the new power peak is only at 6700 rpm. So the cold air + the tune = a win.
Talked to an exhaust supplier yesterday and I'm anxious to get their full length 1-7/8" header set-up coming. Picking that larger header primary diameter to help kill some more low end power while giving a little more on top - unless the new tune is magic, in which case I'll go with their 1-3/4" primaries. Until now, adding any power anywhere would just make the car slower in autocross, so if this new "track tune" allows us to modulate throttle and corner exit faster then we can finally go ahead and look at more power, which is there for the taking. Then we can focus the rest of the season on more suspension bits.
Next up! Two autocrosses this weekend, including Saturday's National Street Tire Challenge and Sunday's Texas Region SCCA Autocross #3, both being held at the massive Mineral Wells complex. Amy and I are driving the Mustang in 2 different classes at each event, and we might even be running on different tire packages as well. We do have a strange, new wheel and tire package we're testing this weekend, which is funny looking and sure to draw some laughs, but it might help cure some of our power issues. If it doesn't work, I won't mention it in my next post, photoshop them out of the pics, and deny we tried it if asked.
More soon,
Former site sponsor
Project Update for June 13, 2011: We had two autocross events on the weekend of June 4-5, where we tested the new engine tuning (throttle mapping) and some new wheels/tires, with the first real promising results for the car in STX class to date. Let's start with the new rear rubber first, then cover the two very different autocross events separately.
17" Rear Wheels and Tires
After the very positive results we had with some very worn and borrowed 18" Dunlops at our Tire Test in April, we wanted to try some fresh 265 Dunlops. We thought about just plopping down for another set of 265/35/18s but instead we tried something different...
Dunlop has the only ST legal/competitive tire that is a 265mm max width for STX in a 17" diameter. This might be one of the only STX cars that can physically fit these 265/40/17 Dunlops under OEM fenders, too. (I've seen these used on an STX classed E36 or two, but those cars had massive compromises in ride height to clear these uber-wide tires) I'd love to run 17" diameter wheels and tires on the Mustang at all 4 corners, but the Mustang's (optional) front 14" rotors and Brembo calipers don't allow this. Up front. But on the rear...
Hell yes! The rear brakes are small enough to allow a 17" wheel to clear, so we bought a pair of wheels and got some 265/40/17 Dunlops mounted to them. The wheels are lighter (TireRack calls them "15.9 lbs") but the mounted 17" wheel and tire (45.0 lbs) is 3 lbs lighter than the 18x9" Enkei FP01 and 265/40/18 Yokohama (48.2 lbs) but is 2 lbs heavier than the 18x9" WedsSport and 265/35/18 Toyos (43.1 lbs). The Toyo R1Rs are way too soft for use on these big cars, so that lighter tire has its drawbacks. Keep in mind the OEM 19x9" wheel and 255/40/19 tire was 57 lbs, so its still 12+ pounds per corner lighter than that. The 265/40/17 Dunlop is actually .1" taller than the 265/35/18s we had been running, so we don't lose any tire height or alter gearing this way.
But we didn't go to the 17" Dunlop for "lightness" - we did it for increased sidewall height and lower cost. The dollars and cents are easy to understand: its $100 per tire cheaper to get the same exact Dunlop Star Spec in 265/40/17 vs 265/35/18. That's $400/set, and hard to ignore. But we've wasted $3K testing various tires and wheels on this car this year, so cost is pretty much thrown out.
Corner Exit Acceleration is the biggest aspect we need to improve on this car (and most autocross cars, for that matter), and we had a long way to go on the Mustang. Throttle mapping was part of it but we're looking for other ways to improve this acceleration direction. The thought that a taller sidewall could reduce some of the shock load to the rear tires crossed our minds. Going to the 17" tire allows for more sidewall height and potentially less spring rate in the tire sidewall.
There are "rules of thumb" regarding sidewall aspect ratios and in one book ( ThinkFAST) race engineer Neil Roberts (Costas' close friend, and an old college racing buddy of mine as well) claims that he likes to use nothing shorter than 40 series tires. Sometimes we don't have a choice, but this time, we did. So we tried it. Looks goofy with 19" wheels on the front and 17s on back (above left), but the 18/17 combo (above right) doesn't look quite as jacked up. We've seen other autocrossers mix wheel diameters front to back, and even OEMs do it (but usually the other way around). So I had planned on running the 17's on back during the first 3-4 runs of the NSTC event and switch to the 18s for the last half. The best laid plans...
National Street Tire Challenge, Saturday June 4, 2011
Note: I've re-written this NSTC event summary several times, trying to be less negative of the course layout and the event in general. This is considerably "dialed-back" and as "PC" as I can make it. I do appreciate all of the hard work that went into putting on this event, and my main gripe is really just the uber-tight course. This is my brutally honest assessment from a 24 year veteran of SCCA autocrossing. Remember - I'm also driving in a very wide car with lots of power and limited rear grip - the proverbial bull in a China closet on a course like this - so that paints my views in a certain light. I wasn't alone in my harsh criticism of this course.
70 cars were there for Saturday's NSTC event, which was an autocross strictly for street tire equipped cars (140+ TW). Great idea for an event, as I'm a big supporter of the various ST classes and feel they are pushing racers out of dated and to some extent broken classes, like Stock and SP. For this series (4 events in 2011), run by the Milwaukee SCCA Region, they have 4-5 classes (all PAX based - my least favorite way to create a class), prizes for each class, and a free set of Bridgestone tires to the top PAX time of the event. Well.... except for any of the Street Touring Shootout class cars - they were not eligible for the PAX ranking or tires. That wasn't spelled out very well (none of the classes/rules were very clear to some) and some competitors felt a bit slighted by the way they handled that. Oh well, now we know - don't enter the PAX-combined ST class if you want to win the tires. And don't show up without an AWD car, either.
We noticed some serious issues as soon as we walked the course. The course... the course was BAD. It was not representative of anything I would call an "autocross", as it was more akin to a gymkhana course, with lots of stopping, crazy tight turns. The course drove over the dirtiest parts of the event site, with 2-3' tall grass over many sections - they needed a lawn mower on this thing. Not kidding. It "walked" so tight and un-flowing, but it drove tighter than Hell. It is hard to describe how bad this course flowed, you just had to drive it. I came to a near stop about 6-7 times on each run, there were never two corners that flowed together, every slalom cone and offset was spaced/timed differently from the one before, and the course was heavily biased to narrow cars as well as AWD cars. For having 40+ acres of asphalt to play with, and for making a 100+ second long course, to never get over 50 mph? That's just wrong. It was dubbed "The Milwaukee Beast" by the Miata drivers. Yes, the Miata guys thought it was a big, long, tight, nasty mess.
After making my morning runs I couldn't understand how our local course designer JJ could have made such an abortion of a course. I found out later that JJ had almost no say over the layout this time; the NSTC event organizers walked the course and made changes to every corner, insisting that it be super tight. A good 90% of the drivers I talked to hated the course and vowed to never to go to another NSTC event.
The throttle mapping WAS much better, but this course made everything feel bad. A go-kart would have felt big and cumbersome in this mess. It was also very hot outside, and with such a long damned course the rear tires got greasy halfway thru the run if I allowed any wheelspin at all. I was spraying the rear tires 3 times after each run, fighting for rear traction through the many tight corner exits. It felt pretty loose and disconnected on the 17" Dunlops and almost as bad on the 18" Hankooks (which I ran up front all weekend and out back after my 4th run Saturday). I did a quick pit stop tire change after run #4 of 6 Saturday, and was faster on the 18" Hankooks, but its not a fair test - this course shouldn't be used to judge anything about any car's handling. The results from the rear tire testing really have to be thrown out, this time.
more...
Former site sponsor
08-16-2013, 01:33 PM
continued from above
Many racers that day were so disgusted with the course that when they heard that Sunday's SCCA Regional event was supposed to run the same course backwards the next day, they decided to back out on their paid entries. We even had a large number not show up for their afternoon runs Saturday - they simply abandoned the event. Some of the local SCCA folks had to work extra corner assignments to cover for all of the missing folks. It was that bad. And it was damn hot - I think I saw 97°F Saturday. We lost more than a couple of folks to heat exhaustion.
There are " Class Results" and even " PAX Results" - I guess you can call them that. The classing was all PAX based, and I'm not a fan of the black magic voodoo they use to make up these PAX factors. The problem here was that its not applied evenly, as you could only use stock class or street prepared PAX factors. Also, the "ST Shootout" cars (ST, STS, STX, STR, STU) have some bogus mega-PAX handicap so they are at the bottom of the PAX results. Just... ignore the PAX results I guess.
You can hear me cursing on almost every in-car video run from that event, linked above, so of you watch the videos make sure you keep the volume down or call "earmuffs" for the kids. On a positive note, Vorshlag sponsored the beer at Saturday night's party, which was frosty and delicious. The burgers and beer were a win, as was Bidgestone's road crew bringing out their mega-trailer, tire changing equipment, and crew (below, left). I was a little embarrassed that they drove across the country to sit in this miserable heat for 3 days and have only 70 people show up. Still, Kudos for Bridgestone for sticking with us all weekend!
In an astounding bit of irony, Andy Hollis won the random drawing for a free set of Bridgestone tires at the end of the event (above, right). Ha!
And again, as negative as this write-up is, I do appreciate the hard work that went into setting this up, I thank the various sponsors, the local SCCA region people who spent 3+ days at Mineral Wells getting this set-up, etc. I'm sure someone liked the course - the fellow that won the tires surely did. Also, big thanks to Brad and Jen Maxcy for doing so much work to help set-up the SCCA's portion of this event and for taking these great pics (more at autoxmax). I barely had time to snap any pictures at all, but here they are.
Texas Region SCCA Event #3, Sunday June 5, 2011
The course designer that was unfairly blamed for the NSTC course (by me and others - sorry JJ!) announced in the afternoon Saturday that "Sunday's SCCA course will look nothing like this", and he stood by his word. With only about an hour of tweaks (and 2 hours of sweeping) Saturday night, still following the same general layout as before, the Sunday course flowed so MUCH better. The stupid tight, herky-jerky mess that was the NSTC course was completely gone. Unfortunately the Saturday event scared off many of our pre-registered Sunday racers (the entire Austin, TX contingent left, as did many other Dallas area regulars) and our attendance dropped to only 54 on Sunday. That's a shame, as it was a lot more fun running this more "normal" course and they really missed out on a fun event. But it was hotter still - we saw 103°F when we left.
Amy ran in the "W" PAXed Womens class in the morning "A" heat (3 runs in the morning, 3 in the afternoon), but with 1 other STX ladies driver there wasn't much "PAX effect" on the results. She knocked down some blisteringly fast times in her 3 attacks at the course, even with a migraine headache that started Saturday afternoon - she said her head felt like it was going to explode wearing her helmet on Sunday. The heat was a big factor in this, but she still managed to put up the 5th fastest PAX time for the event in those 3 runs and clobbered both W and the STX open class. She passed out inside the timing trailer after she made her 3rd run and didn't drive in the afternoon at all.
I ran in STX with the usual suspects - Brad Maxcy and Chris Ledbetter in their AST/Vorshlag/Hankook equipped 328is BMWs, plus Ledbetter's co-driver Sherrie. We ran the "B" group and were running very similar times to each other, trading off the lead almost every run - we finished our 3rd runs within .1 sec of each other. I was feeling better about the performance of the car, especially considering that Amy was over 1 second quicker at a 78.040 sec run. I went to her and asked what she was doing differently - in her migraine daze she said she was smooth, attacking the offsets, stepping on cone bases, and just driving well. She also managed to do the whole course in 2nd gear, where I was shifting to 3rd in the back section. I think the excessive shifting was slowing me down, so in the afternoon I left it in 2nd and tried to be smooth.
After my 4th run I was quicker by a few tenths and in the lead again, at least for a short time. Maxcy and Ledbetter got quicker on their 4th-6th runs, so I was back in my normal 3rd place by day's end - but closer than ever (.391), and Amy was still quicker then all of us, in the same car in only 3 runs, and ran the course when it was dirtier. The throttle response was markedly improved and the car was handling better than it ever has in an autocross. So I was excited with the performance of the car overall - its finally showing some promise. STX class beat STS, STR and STU that day, with Lebetter PAXing 7th, Maxcy 8th and me back in 12th.
So we left Mineral Wells Sunday night sweaty, dehydrated, in pain, and generally dead tired from being at the event site for 3 days. We weren't out there as long as some others, but it was still a bit of a whipping.
Up next: Our new autocross timing system has now arrived (big thanks to SPS!) as well as a bunch of new cones, so we have everything needed to hold our own private autocross tests now - so expect to see some more tire testing, soon. We talked to the guys at Bridgestone and they were keen on possibly getting us a set of RE11s to go head to head with the Hankooks and Dunlops. We will see. Next event: 2-day Divisional Autocross this weekend in San Antonio.
Cheers,
Former site sponsor
08-16-2013, 01:34 PM
Project Update for June 22, 2011: Amy and I ran the Mustang at the 2-day SCCA SouthWest Divisional # 2, hosted by the SASCA and Spokes regions, and held at the Retama Park horse track facility in San Antonio, TX. We towed from Dallas down to San Antonio on Friday, pushing through some ugly traffic on I-35, and once down there we saw an ambient temperature of 105°F that afternoon. Oh boy, summer was in full force in south Texas! We rolled up about 6:30 and the welcome party was going full swing, with a Carl's Jr Burger Bus cranking out great food (Vorshlag sponsors the SW Div series welcome parties; this sure beat cold pizza!). We checked in, teched, and walked what looked to be a rather nice course, for the size of lot they had. Hat tip to Vivek on smooth, flowing, and very different course designs for both days.
First off - the SASCA club put on a great event for their first Divisional! The weather was warm but with only 82 entrants we were done early Saturday and Sunday, both. The largest class was XP with 14 drivers - with V8 Miatas and all sorts of cool rides - and they were all smokin' fast. The region put on a great Saturday night dinner/party inside the Retama Park facilities (*air conditioned!), where we put away two kegs of cold Shiner beer and lots of delicious Bar-B-Q. A huge number of us stuck around that night for about 4 hours, talking and drinking, bench racing and lying. This is why 2-day autocross events are so much fun.
So how'd the Mustang do? It was driving great, as it has been ever since we got the throttle mapping sorted. The Hankooks took the heat (with ample tire spraying after every run - especially the rears) and dug through the dirty asphalt surface fairly well. We didn't make any radical changes at this event - for once - and just used the shock and tire pressure settings we used at the last event.
So the course Saturday was a bit twisty, with 3 "turn-arounds", and walking it I could predict that the AWD cars would do very well - and they did. John Hale put a second on the STU field (and 2 seconds per day on the other ST classes) in his STi over both days... FTW (see above). The R compound and slick-clad cars also PAXed well, I think due to an abundance of big, sweeping turns on Sunday's course? Amy and I PAXed 19th and 21st out of 81, but we straight timed ST, STS, and were darn close to STR (Amy almost beat the class), so I felt the Mustang did well despite our somewhat mediocre PAX finish this time.
For our class results I won STX (that's a first) and Amy took 2nd in the PAX'ed "W" class, losing by a scant .3 sec to a CP Mustang driver. Amy was faster than me overall, driving smoother as usual. We just about tied on Saturday (.04 apart) but she straight timed me on 4 out of 4 runs on Sunday, with a .3 sec gap ahead of my combined times over both days. I've watched all of the videos and analyzed the pictures (300) and she's smoother on braking inputs, throttle inputs, and maintaining more speed through transitions than I am. My runs have much more brake dive, more power oversteer, more choppy driving. I need to work on being smoother on the inputs, again. Did I mention I was hung over BADLY Sunday morning? That didn't help. We also we need a new data logger that we can look at driver data between autocross runs. MaxQ is out of business, so what's the next best, PDA-based (or included LCD readout), easy to view, 10 Hz GPS+Acclerometer data logging option???
me = too much Hooning, too abrupt on the brakes
Again, due to the small event turn-out (I'm talking to you, Texas Region SCCA racers who skipped this event. We had only 7 folks from our massive region there!) we finished early both race days to beat the heat; even with 4 runs, we were wrapped at 12:30 am on Saturday and 11:30 am on Sunday. It was 86°F one day and 90°F the next after the last runs, but crept up past 103-107°F in the late afternoons. We spent Saturday afternoon in the pool at our hotel - my kind of autocross weekend.
Dust, dirt and marbles were in abundance, both on and off-line
After we wrapped up Sunday we loaded up and headed back up to Dallas, but within 15 minutes were pulled over by Texas DPS for a "road side truck and trailer inspection". They hit thousands of trucks+trailers that weekend, apparently, but we had all of our paperwork and passed easily. 2 hours later we pulled over to finally eat lunch, then I heard a big leak on a truck tire. Nail in the tread. We were parked 75 feet from an NTB and even though they wouldn't plug/patch the tire (Discount Tire did on Monday) they helped us put the spare on. A scant 5 hours after leaving San Antonio we were back to Dallas - whew!
In-Car Videos
The month of July gets a little nuts for us, as after the July 4th weekend we have 3 weekends booked with autocrosses. 2 Tex Region SCCA events sandwich another SW Divisional event (College Station - on concrete), with Costas back on board co-driving in STX at most or all of these. I have a few new bits for the Mustang in-bound (JTL oil separator, not much else worth discussing) and at some point in July we're going to try to get our next private tire test in (Vorshlag's new timer system and pylons have arrived).
Stay tuned,
Former site sponsor
08-16-2013, 01:37 PM
Project Update for July 6, 2011: Lots of little things going on with our Mustang since the last post. Apologies in advance for the pictures - I left my Nikon at McCall's on Friday (working on his Z3 LS1) so I took all of these with my iPhone. Let me catch everyone up...
FCS1219311: 2011 MUSTANG WORKSHOP MANUAL @ $180.00/set
The 2 volume Helms Ford Factory Manuals were finally printed for the 2011 Mustang, and we got ours last week. Now we can hopefully find all of the little fixes and tricks to maximize everything. I looked in the power steering section - zero diagnostics help.
As you can see above we have added some underhood silliness, above... I'm normally not one for "bling" but most of this round of mods has a purpose.
I'm sure the blue coil covers will get some "ricer!" grief, but oh well. So I started by removing the coil covers (they pop off in seconds), then cleaned them with soap/water, then wiped them with alcohol. Next came five sprayed on coats of Rust-oleum "Ford Blue" high heat engine paint and then a couple of coats of Rust-oleum "High Performance Wheel Paint" clear coat. It was super easy to get these off and on, and only took about 30 minutes of work (plus drying time). This blue matches the 2012 Boss 302. Yea, its just flash, and all of the guys here at Vorshlag were hating on this mod, as was my wife Amy ("What next, a Superman cape?!"), but its an authentic tribute to the new Boss 302, so screw you guys!
Next up was the JLT oil separator catch can kit for the 2011-2012 5.0 and Boss 302. We picked the the "Passenger Side Kit" ($119) and it installs in literally seconds. Two squeezed clamps (which you can un-snap by hand) to remove the old vacuum tube, then the kit pops on in place - the hose from the intake to the passenger side valve cover. During high RPM use (and really the subsequent "high vacuum" period on engine deceleration) it will catch the oil vapors (separates and traps it in the catch can) instead of burning it inside the engine. I've seen guys track these 5.0s start pushing oil out into the air cleaner, but its usually people that live on the rev limiter. Last up is the Redline Tuning Gas Strut hood lift kit, which I also got from JLT. This simple to install $84 kit comes with all of the goodies to replace the stupid stock hood prop rod. If you park into the wind and leave the hood up (which we do often at the drag strip, road course events and autocross events) the hood can rattle and flop around, even fall off the prop rod. Now that we have real hood struts, these issues are resolved.
Last up, the video of the "Electronic steering shudder" feedback issue we've run into on our car:
This video describes what we're seeing and shows in in great detail. If you know anyone at Ford and would like to send them this link, please do! Also, anyone road racing the new Boss302S (with the same electric steering) - have you seen this?
We're not trying to blame Ford for a poor design, just want to find the sensor or broken wiring or whatever is causing this horrendous cyclical feedback in the steering. Its actually pretty dangerous... once it happens you have to pull over and almost come to a complete stop to get it to stop. And its getting worse; it happened to me yesterday twice, on the highway, going perfectly straight.
Yes, we might have inadvertently done something to cause this - I'm looking for the solution, and I'm willing to pay for new parts if its our fault. We've pulled out the "excessive" negative camber up front (that someone suggested as the cause), and zero'd the front toe, but so far nothing has fixed it. Any suggestions or "its happened to us too!" experiences are welcomed.
Thanks,
Former site sponsor
08-16-2013, 01:38 PM
Mini-update for July 8, 2011: Just a few pictures of the first prototype S197 Mustang, D-Force/Vorshlag, 5-spoke 18x10" wheel shown on our 2011 Mustang GT. This is the first stab at getting the offsets right, and we know we might be going back and tweaking the numbers slightly. We wanted to get a grasp on weights (18.7 lbs) and caliper clearance on this first 18x10" set before we ask for changes to the molds.
They clear the front Brembo 14" rotors and calipers by a huge margin up front, and it looks like the offset we have might just work front and rear. Its hard to tell without tires mounted, and just slapping them on at full suspension droop. On Monday we'll mount up some tires and post more pictures.
The rear can go inboard another inch, and we might move the wheel inboard 5-7mm to gain fender clearance out back. Again, we'll know more when we get tires mounted and have the whole set on the car. If they fit we'll start street/track testing them right away.
So far I'm very happy with the initial test fit - stay tuned for more information about this wheel. And yes, we're trying to make it fit GR chassis Subarus as well (which shares the 5x114.3mm bolt circle). Costs should be "affordable" (read: sub-$350) given the quality, light weight, and somewhat narrow market range for a 10" wheel like this, with ETA for production at 12-24 weeks. This is an exclusive D-Force wheel offering that will be stocked and sold by Vorshlag.
Cheers,
Former site sponsor
