Go Back   Dallas Fort Worth 5.0 Mustang Club > 5.0 Mustang Forum > Interior/Exterior
Interior/Exterior Post new mods or questions about the inside or outside of your mustang
Old 04-08-2014, 05:39 PM   #1
01svtL
01svtL's Avatar
Default What backspace?
I'm looking at 19x9.5 and 19x10 wheels.
Autoanything has two different backspacing available on the 19x10.5: 7.02 and 7.52, both have 45mm offset. How would one fit as opposed to the other?
Is 45mm offset too much for a 10.5" wheel?
2014 Ruby Red Metallic GT
3.73
GT500 Quads
01svtL is offline   Reply With Quote
Old 04-08-2014, 06:26 PM   #2
*Messed up, so I deleted this first part.* I'm not exactly sure on the max and min offset of each width, but I know most try for around +43mm on a x10 wheel
Old 04-08-2014, 06:52 PM   #3
01svtL
01svtL's Avatar
Yea I'm wondering about that half inch difference on the backspace.
3.73
GT500 Quads
Old 04-09-2014, 02:43 PM   #4
BV600
Originally Posted by DirtyD View Post
The higher the number the further out of the fender the wheel sticks, except deep dish wheels are a little finicky. If it's a concave/flush face wheel. I'm not exactly sure on the max and min offset of each width, but I know most try for around +43mm on a x10 wheel
I thought the lower the number the more sucked in?
for example New Edge have like 22mm offsets and the stick out a lot on s197s, while ours are sucked in.
Old 04-09-2014, 03:15 PM   #5
It depends on the design of the wheel too. If it's not really a deep concave wheel, a lower number will stick out, which I think is the case with new edge wheels.
Man, I thought I finally had this whole offset thing down, but now you have me wondering again. lol
Old 04-09-2014, 03:21 PM   #6
BV600
I have no idea now lol.
Honestly when im searching for wheels I go on late model or AM and look at the offsets listed for the common wheels. Like the SVE drifts in 19x9.5 are 35mm
Old 04-09-2014, 03:31 PM   #7
01svtL
01svtL's Avatar
It depends on the design of the wheel too. If it's not really a concave wheel, a lower number will stick out, which I think is the case with new edge wheels.
You pretty much just said the same thing.
But, I'm thinking a higher number is sucked in more, so a 30 offset will stick out further than a 40. That's my understanding. I just don't know what is too much or too little. I also don't know how backspacing affects it.
3.73
GT500 Quads
Old 04-09-2014, 03:38 PM   #8
Yeah, I messed up. Guess I wasn't thinking clear enough when I posted yesterday. That's my fault fellas. higher offset is set further away from the wheel center, meaning the inside of the wheel is going to be futher in towards the suspension and inside of the wheel well. deep dish wheels though I think can get away with a lower offset since the hub is located closer towards the center of the wheel to give it lip.
01svtL, there is actually a guy on SVT Performance that is running 19x10.5 ET45 that I saw today. Wheels seem to fit.
Old 04-09-2014, 03:51 PM   #9
01svtL
01svtL's Avatar
Yea I know the offset is ok, i just don't know if that backspace pushes it back out. I believe the standard offset for that wheel at that size is 7.02, but they don't have it. They DO have it in 7.52. But I don't know what that means or how it affects it. I just don't want the wheels to stick out.
3.73
GT500 Quads
Old 04-09-2014, 04:14 PM   #10
Maybe a difference in the relief of the spoke design?
This is from TireRack. It seems that backspacing is how much room there is between the mounting pad and the back of the spoke/wheel.
Backspacing, similar to offset, is the distance from the hub mounting surface to the inside lip of the wheel (measured in inches).
