Old 07-05-2013, 12:01 PM   #1
Did you install the springs on stock struts? Did you also reuse the stock strut mounts? If you did, did they come apart at all? Also, did you make sure to reinstalled the rubber sleeve from the stock springs onto the BMR springs?
If you didn't reinstall the sleeve, then what you are hearing is just spring chatter. Since the springs are progressive, you saw that the bottom coils are tighter wound together. Since it takes a certain amount of preload force to initially compress the spring, the passenger side spring is likely to chatter on the spring seat of the strut. Mine does this only when I don't have a passenger riding, and I'm on a slightly washboard/bumpy road, making the spring compress and decompress quickly.
Old 07-05-2013, 12:15 PM   #2
Informative DirtyD. Great post.
Old 07-05-2013, 12:29 PM   #3
Thanks. I chased that problem for awhile. When I finally got the chance to install my new struts, we ended up wrapping the first or second bottom coil in electrical tape because I forgot to get my sleeves off my stock springs. For a few months the noise was gone, but I think the tape is basically gone now from constant rubbing under compression that it is starting to be heard again.
