Old 06-16-2013, 03:12 PM   #1
kn7671
Originally Posted by re-rx7 View Post
Larger wheels also affect the gear ratio.
Wrong. Wheels have absolutely no relation to gear ratio.
Tire diameter effects gear ratio, but you can choose tires for larger wheels that have an equal tire diameter as stock 17, 18, or 19's in 20" sizes without affecting gear ratio.
That being said, if you choose tires with different diameter than stock, say approx. 3/4" shorter or taller, the effect on gear ratio is minimal, about 3% on average. At 70mph you'r speedometer would be about +2mph with smaller tires or -2mph with larger tires.
Originally Posted by jng2985 View Post
20's offer more tire choice's, but a loss of power.
You don't lose power if the overall weight of your 20" wheels/tires are the same overall weight as the stock 18" or 19" wheels/tires, which isn't too hard since the factory wheels are usually on the heavier side.
Why not just a nice set of 18's with a 1'' drop all around? Nice and subtle.
Agreed, the right 18" wheels can look nice, but you need to know what your plans are for the brakes, as more of the 18" wheel choices will not work with the larger 14" Brembo brakes, or other big brake kits.
Originally Posted by JDBishopArts View Post
The whole 19" and 20" staggered never made much sense to me.
The Corvette has done this since the C5 in 1997. Other car high performance car manufacturers do this as well, so apparently there is real benefit when tuned and setup. Just because it doesn't make sense doesn't mean we should fear it.
2015 Mustang GT - Black w/Perf Package
kn7671 is offline   Reply With Quote
Old 06-16-2013, 03:57 PM   #2
At that point you will sacrifice ride quality. Thats why if the car is lowered 18's seem to work fine.
Old 06-16-2013, 05:08 PM   #3
kn7671
Most people don't realize that the Mustang comes with several different diameter tires, spreading over 1.1" in difference.
V6 with 17 = 28.0"
GT with 18" = 27.2"
GT with 19" A/S = 27.7"
GT with 19" Brembo = 27.2"
Boss 302 rear = 26.9"
GT500 with 20" rears = 27.9"
In this regard, if you had a normal 245/45R19 (27.7") All-Season equipped GT, which is .8" taller than the 285/35/19 (26.9") rears on a Boss 302, and then jumped to to a 20" 285/35R20 rear tire (27.9") would give you .4" shorter sidewall than the stock 19" AS tires, but a 100% equal sidewall height to a Boss 302 rear tire.
Additionally, the 20" tire at 27.9" rear tire will give you a better ride than the 26.9" rears, while giving a little more overall grip from a slighty larger contact patch.
Old 06-16-2013, 06:31 PM   #4
V6 with 17 = 28.0"
GT with 18" = 27.2"
And there you have it. Solid post sir.
Old 06-16-2013, 07:04 PM   #5
18s are definetly noticeably smaller when comparing to 19s and obviously more noticeably with 20s. I myself am tempted to go the 18s route on the Forgestar FR5s I want buy, but in the future want to go big brake as well (brembo at a minimum) and don't want to have to deal with getting different wheels again. I just hate how 19s are such the odd cat with tire selections and 20s are EXPENSIVE!
Old 06-17-2013, 03:33 PM   #6
+1
All the high performance cars use a staggered wheel fitment. Corvettes, Vipers, Ferraris, Porsches etc. Even the GT500 comes stock with 19s front and 20s rear.
As others have stated, wheel weight makes the most difference for unsprung weight. TSWs Nurburgrings are excellent. I saw one member on another forum with a 19X9.5 TSW N that weighed 22lbs. In that size is it definitely lighter than stock AND allow for a larger brake kit. Also on those other cars, because the front fender of those exotics are generally much shorter than the rear fenders, if they ran same size front and rear wheels, the fronts would look bigger.
