Old 09-13-2013, 02:21 PM   #31
Yagermeister
Yagermeister's Avatar
Shifting the Boss at 7750 right now and plan on staying there until the winter when I do the crank trigger wheel, Boss springs and tensioners, and the 11mm/290° Cobra Jet exhaust cams...then I'll go to 8000
2010 GT500
Old 09-13-2013, 02:29 PM   #32
I'm interested in seeing your results. That kind of power with bolt ons and a stock longblock would be impressive. The problem with it is having to rev the hell out of the stock valvetrain. In a couple more years I bet we start seeing a lot of cars running the Boss intakes spinning them in the upper 7k range starting to have valve/springs issues.
Yeah, I would just wait and do all that at once just to avoid any potential headaches.
Old 09-13-2013, 02:36 PM   #33
I agree.
Old 09-13-2013, 02:38 PM   #34
Yagermeister
People are not having any headaches shifting at 7750 and are making the numbers mentioned without having to spin it higher right now so I'll be happy for awhile
2010 GT500
Old 09-13-2013, 02:55 PM   #35
Stock longblock including cams/valvetrain, stock heads, through an auto making 490rw? LOL, you're asking an aweful lot of that lil smallblock and expecting to it live.
Old 09-13-2013, 03:01 PM   #36
Yagermeister
Steve I said 450-490 depending on choices of parts and fuels. I never said I will get 490. If I get 450 on 93 I'll be happy...however...my car will not see a dyno so we won't know numbers but we will see track times...shooting for 10's in cool and warm weather like wbt
:beers:
2010 GT500
Old 09-13-2013, 03:27 PM   #37
KalEl370
:beers:
I'm interested to see how it turns out for you. I might do this early next year. I have the pulse ring, upgraded valvetrain, built motor with billet gears and stage 3 cams. I haven't had mine on the dyno yet but hopefully will be attending the dyno day at TS. Keep ua posted!
2012 base GT MT, 3.73s, Steeda shifter, Boss intake, jba LT headers Roush wheels
KalEl370 is offline   Reply With Quote
Old 09-13-2013, 07:35 PM   #38
Dan12GT
Dan12GT's Avatar
I've heard the CJ manifold picks up more power earlier than the boss maybe a 1000 rpm difference? Not sure if that power is more than stock at 4500-5500 but the losses are less in that range than t he boss manifold and it has more potential for peak horse power due to revving super high.
Old 09-14-2013, 03:25 AM   #39
wbt
You won't get 8K out of the auto processor. The only way you are going to get there is with a non-computer controlled auto and a Boss processor.
wbt is offline   Reply With Quote
Old 09-14-2013, 09:21 AM   #40
Yagermeister
For a test, a tuner gave me a tune last year that had some special work done that let the auto shift at 8100 but I felt valve float or the car missing due to no trigger wheel. After three passes we took it off my car...so it is possible but not recommended until the trigger wheel and valvesprings are upgraded.
2010 GT500
Old 09-14-2013, 09:51 AM   #41
I will never understand why some people feel the need to spin a stock motor out of its effiency range when there is so little power to be found there and ends up doing more damage than anything else.
Old 09-14-2013, 09:58 AM   #42
Yagermeister
With the exception of rods and pistons along with heads that flow only marginally better, our GT engines with a Boss intake are NEARLY identical to that of a Boss engine. The Boss 302S and 302R teams spin it that high for hours on end. For a quick 10-11 seconds we are good. Those race teams must not know what they are doing spinning it that high
2010 GT500
Old 09-14-2013, 10:04 AM   #43
Yagermeister
The Boss intake changes where the GT motor is efficient by moving the powerband higher. The CJ does the same but even higher than the Boss
2010 GT500
Old 09-14-2013, 10:24 AM   #44
Rods and pistons can have a big affect on Rpms espeically if the weight is different.
Old 09-14-2013, 10:31 AM   #45
Yagermeister
re-rx7, you are correct but have you seen the Boss rods and pistons? They look and are nearly identical to a GTs except for the process in which they are made. They are also nearly the same weight so I don't think that argument can be used here...but I've been wrong before as my wife tells me
2010 GT500
