I guess my question to that would be if motor mounts were put on to raise the engine a bit, would that throw off the pinion angle?
Long tubes scraping
Thanks for the info I'm looking at ARH longtubes right now wondering if I'm going to scratch everywhere I go to. Eibach sportline kit with non adjustable shocks... Sexy look but PITA I am going to say what everyone told me man look Into adjustable struts and shocks that would give you a stiffer ride with less give that may give you a little clearance.
You won't regret getting them installed! They're awesome!
My StainlessWorks don't scrape and I'm dropped on Sportlines too.
I don't scrape anywhere but my driveway, but that is one of the most important places for me NOT to scrape.
Try going up the driveway at an angle
is it possible to back in? or do you get the same result? also yes, motor mounts are adjustable, steeda has some good ones. dont buy upr. also if you have an adjustable UCA, pinion angle shouldnt be an issue. or you can get a aftermarket driveshaft..lol
Get Steeda motor mounts, that's what Jeff runs.
I've got sporttllines without isos and my LTs scrape everything.
yeah, i have looked into the adjustable motor mounts but they only go down. I don't know if its in the cards for you, but running 20's would give you more clearance and fill the wheel well more if you did raise your coilovers a tad.
Just back in at a angle. Problem solved
