-   -   5w50-ouch (http://www.dfw50s.com/showthread.php?t=2413)
JDBishopArts 09-10-2013 11:50 AM
I'm running 5w20 Mobil 1. Always run Mobil 1 with no issues. On boosted and non boosted cars. I wanted to run Amsoil but I couldn't find a dealer that didnt' want an arm and a leg. I'll order it next time.
The track pack does require you run ford recommend oil to retain the warranty.
El_Tortuga 09-10-2013 02:01 PM
Originally Posted by Torsion (Post 49440)
I got a little better pricing from the Frisco Ford dealer's parts department last time I bought 5w-50.
I'm track pack too, and I'm stickin' with Motorcraft.
Thanks. I'll remember to check that on the next round.
El_Tortuga 04-17-2014 02:00 PM
Should have remembered to check. I went down to 5-star in Carrollton yesterday and they've jacked the price up from $9.90/qt to $14.84/qt. Crazy!!! Bought it online for just under $10/qt.
TwoQuack 04-17-2014 08:10 PM
Originally Posted by kn7671 (Post 43930)
5w50 is the standard weight in the Track Pack cars, just like the Boss models.
Same spec for the Aluminators and all Roush cars.
Toby 04-17-2014 09:13 PM
Originally Posted by re-rx7 (Post 44044)
The best racing oil is the cheapest. Ask Toby. Valvoline VR1
VR1 is junk plain and simple. Last engine I tore apart that was using VR1 had an 1/8 inch of sludge in the oil pan. I would not recommend that crap to anyone. Personally I like mobil 1 but have recently become a fan of amsoil. We are a dealer and regularly stock it at the shop with a few select filters.
Just my .02
Crimson600+HP 04-17-2014 09:15 PM
If you heavy road track your car is it recommended to run 5w-50? Just curious, anything to help my overheating problems on the track. Currently run 5w-30.
El_Tortuga 04-17-2014 09:34 PM
Doubt that it will help the overheat, but should help protect the engine at the high temps.
Crimson600+HP 04-17-2014 10:13 PM
Anything helps at this point. With the recent quote on my hail damage from USAA ($1k) I will be going to a collision place for a full quote. If they can cut me a better quote, I will just keep the cash as the damage is hard to see. Use that to fund maybe a new radiator and tiger racing hood. Trying my best to cool the engine down, so if the oil can help, I'm all for it.
garner 04-18-2014 03:38 AM
Paceline on veterans is really good(they've done the work on all my cars) but they're pricey. Might wanna see what caliber quotes, I've heard they're good too
Soulowd 04-18-2014 04:47 AM
I have track pack as well and I'm sticking with factory specs as well. There is a brand called Redline that a lot of ppl swear by but I've also heard there is a Mobil 1 in 5w50. I know for sure that there is no Royal Purple at that weight
Toby 04-18-2014 01:32 PM
If you are having that big of an issue with heat which would not surprise me with the large intercooler in front of the radiator. I would suggest going with a larger radiator along with doing a remote mounted oil filter and adding a large air to air oil cooler. That should remedy your heat issues.
We can get you the components needed for this modification if you are interested.
Oh and yes run a thicker oil when you track it. It may not affect cooling but it will definately help to protect the bearings will the huge amount of stress you are putting them under with the power and extended runs at the track.
Disturbed 04-18-2014 02:18 PM
I wanted to jump in and give some useful advice on this thread regarding the 5w50 motorcraft.
Ford is obviously going to recommend their own brand. But this is an "intended use" package on this car, and therefore Ford assumes at least one of us will actually do extreme track work and doesnt want the motor seizing up. Currently, if your a worry wort about your warranty, you can only use Motorcraft 5w50 or you can use the Castrol Syntec 5w50. These as far as I know are the only two Ford will recognize as being covered under warranty due to the specific certifications.
However, UOA's have already shown that 10w30 Amsoil, and even Royal Purple are superior, at least on the analysis sheet. Ford's engineers are not stupid, but what their not telling you, is about the quality of their oil. Under street racing conditions or light tracking, the 5w50 Motorcraft is shearing to a light 5w40 at running tempurature. Under extreme conditions, its even shearing down to a heavy 5w30.
By this, I would rather run a quality oil thats ALWAYS a 30w oil with minimal shearing. Amsoil 10w30 is my choice. And the 10w is soley because we live in Texas.
With a quality 30w, your going to have the same if not better protection, and slightly improved fuel mileage. If your worried about warranty, you can use the cheaper Motorcraft. The same engine runs 5w20 in non track pack AND non boss cars. They assume its your daily driver (the base model), not a race car.
Pick the oil for your intended use, and pick a quality one. :Bye:
Edited for JDMLOL's reading pleasure
JDMLOL 04-18-2014 03:40 PM
5w50-ouch
Originally Posted by Disturbed (Post 69895)
The same engine runs 5w20 in non track pack / boss cars
They don't expect boss cars to be on a track???
Disturbed 04-18-2014 04:37 PM
You misunderstand
The same engine is in all three trims. The oil changes to 5w50 in their higher trims because they expect them to be driven hard.
I think you know what I meant.
JDMLOL 04-18-2014 04:47 PM
Originally Posted by Disturbed (Post 69910)
You misunderstand
I do understand fully. I just expected the boss to be the most track-oriented of the bunch...
