-   -   Engine locked up at 4500 miles (http://www.dfw50s.com/showthread.php?t=730)
TrueStreetMotorSports.com 12-05-2012 04:51 PM
Guess i should chime in, We removed the valve covers's and checked all phasers and limiters, cams, timing chains and tensioners. All are in tact and look to be brand new as they should. We checked oil to see if for some reason oil is burn up, nope all looks good. So from there we took oil filter off and cut it open to check for bearing material, metal, ect. No bearing material but there is some metal in the filter. Does not look good, Not sure what could happen to make a motor lock up with no oil issues, no bearings issues and metal in the pan. Ill try to keep you guys posted as we move forward.......
here are some pics of cams in place, everthing up top looking good. Keep you guys posted as we contunie
http://i230.photobucket.com/albums/e...cobra/Cams.jpg
http://i230.photobucket.com/albums/e...obra/Cams1.jpg
DirtyD 12-05-2012 04:56 PM
At least those cams look sexy sitting there. That's a bright side. :D
BLK2012GT 12-05-2012 05:51 PM
Well there is still a little hope that there might not be anything wrong with the engine but won't know for a few days and not till they tear down to the oil pump gear.
Thanks Clint for chiming in and clearing up everything.
Slow6 12-05-2012 06:39 PM
Sorry to hear this happened.
BLK2012GT 12-05-2012 06:42 PM
Originally Posted by 46Tbird (Post 11313)
By the sound of the symptoms, I'm guessing it dropped a valve.
Regardless of what happened, I'm sorry to hear it. I was anxious to see what a full top-end built coyote could do on a stock short block.
There still that chance.:favorites13:
Cabikejumper 12-06-2012 03:31 AM
When my crank gear fucked up, it locked the motor up. No oil issues or anything other than that. Unsure if the 2011+ has them or not.
Garceeya 12-07-2012 01:16 PM
Stories like this make me not want to mod my car. Hope it is not to bad.
TrueStreetTim 12-07-2012 01:37 PM
Moved http://www.mustangevolution.com/forum/f358/t294722/ here to add to the discussion.
BLK2012GT 12-07-2012 02:08 PM
Have you guys started on my car yet?
Slow6 12-07-2012 02:23 PM
Their still finishing mine... lol
