I plan to make that on race gas at about 12, but im turning big rpm and have 2 turbos similar in size. |
I plan to make a plan to build both and see where I end up price wise. Since huge horsepower isn't my end goal it will most likely come down to price. If the 408 is within a certain amount of the 347 then I will start purchasing parts for it but if it is a lot more then I will stick with the 347, make my 650 to 700 hp and be happy. |
I know you arent trying to make big power, but the 408 just makes more sense. If I could afford another build Id sell you my 351 shortstroke and go to a 427 in a heartbeat... |
I wonder who could convert that intake for me and what it would cost? I know a new one is around $450. I was looking at the spyder style intakes vs the one I have for my new build anyways.
I have a spyder upper elbow and an accufab 90mm race tb I will sell you if interested...
Oh and to swap from a 8.2 deck to a 9.5 all you will need is an ac bracket, headers, distributor, and oil pan. other then basic engine parts, ie intake manifold, etc your timing cover can be reused, engine mounts, trans, clutch setup. I am not sure about the brackets on that novi setup though. If it is not bolted ONLY to the cylinder head the you may need different brackets to make that work.. realistically the only things you will need to buy are the ac bracket and dizzy. Everything else you are planning to buy anyways so cost is the same.
