Still think Dave's car will be faster trap speed wise which should transulate to a win if the power to weight ratios are similar... the nitrous car isn't going to hook if on anything but a slick or MT DR...
You 2 need to go to Crandal where they dont care about roll cages and tech, and do a best 2 out of 3 or 3 out of 5 showdown... |
keep practicing shifting
Are either cars going to need to shift to fifth? That could cause a problem for the blower car if its going through the last few hundred feet bogging...:sad72: The nitrous car will have a huge advantage here with all the torque...
I could only go about 120 at 7200 rpm, and you guys are spinning 7800-8000 correct? I would hope both of your cars would trap in the 135-140 range, so if that's the case you need a tall tire (28-29") or you are going to need to shift. If David has 3.73's he's gonna have to shift regardless of his tires. He'd be better off running a 26" slick if possible. Just some friendly advice.:angels25: Im good at math and stuff. |
Jeff vs David
I have 3:31s too. No slicks yet. Spin all day.
you shouldnt be afraid since you have that awesome tq curve lmao |
Is either car running?
David's car was moving under its own power Saturday when I went up to ts with my car. Car sounds damn good. I helped push a non running black car into the shop at closing, but not sure if that was the other car or not.
