-   -   Max tire size on 19x9 brembo wheels? (http://www.dfw50s.com/showthread.php?t=1454)
Hddcrasher 04-07-2013 09:27 PM
So I am looking for long term tires on brembos. Stock seems to be 255/40/19.
Will a 275/40/19 fit and clear? Would that be a bit much for a 9 inch rim?
Intended use is daily driver. No 1/4 drag events.
Thanks for any advice here
Dan12GT 04-07-2013 11:48 PM
Don't think a 275 fits. I could be wrong on that.
BeastStang1302 04-08-2013 12:16 AM
I've actually been told that 275 is the max that you can go on the brembo wheels. I actually plan on going with this size myself, if I don't decide to buy different rims.
pohnjarker 04-08-2013 12:34 AM
285 is the max you can go with a slight bulge, 275 fits better with no bulge.
i have 275 V12s on my stock brembo rims and they look/fit great.
DirtyD 04-08-2013 06:58 AM
275/40 is the maximum recommended tire size in a 9" wheels if the car will see any kind of quick turning, hard cornering, etc.
If you simply just drive to and from work, without any fun whatsoever, you can run a 285, but still not advised.
I'm going to running a staggered 255/40 & 275/40 Continental DWs when I upgrade the tires.
pohnjarker 04-08-2013 09:17 AM
haha, dont be so dramatic Derek, you can have fun on 285s.
i wouldnt take them on a road course, but anything you will be doing on the streets will be fine.
DirtyD 04-08-2013 12:41 PM
Depends on how road coursey some people get on the streets. Lol
I make slow turns in 2nd gear at 15 MPH, so I'm sure I'd be fine. Haha
DirtyD 04-08-2013 12:42 PM
Plus, I want a slightly taller rear tire on mine, because I don't like the idea of running a shorter rear tires than the front. Unless I stepped up to a 19/20 stagger with a 285/35/20 rear.
pohnjarker 04-08-2013 12:56 PM
if you're going up to 20s, you fit a 315 on a 20x10...ask me how i know :-D
DirtyD 04-08-2013 01:26 PM
Sorry, I meant to type 295/35/20
DirtyD 04-08-2013 01:27 PM
Nittos don't count because they run small. :p
pohnjarker 04-08-2013 01:59 PM
haha, i know, otherwise id have a 305.
Hddcrasher 04-08-2013 06:52 PM
So looks likei 275/40/19 all round is what I will do. I want to be able to rotate the tires.
But, Dereck why the stagger on same rims? 255 front 275 rear?
DirtyD 04-08-2013 07:34 PM
I like the wider rear tire look. I'm pretty religious about keeping my tires balanced and such, so I shouldn't have to rotate them at all. I'm sure other people out there running staggered setups don't have a problem.
pohnjarker 04-09-2013 04:43 AM
I ran 275 all the way around and preferred it only because i could rotate my tires. i would burn the back tires too much, then swap them with the fronts and get a little bit longer out of the set.
the staggered approach does look pretty sweet though.
currently i have 315/20 on a 20x10 out back and 255/20(i think) on a 20x8.5 up front. takes a few lbs off the rotational mass up front as well.
