-   -   Anyone have the 2013 stereo wiring diagrams? (http://www.dfw50s.com/showthread.php?t=1683)
svostang 05-08-2013 03:56 PM
I am trying to install the shaker 1000 from my 2012 GT into my 2014 and ford has changed the wiring with the shaker pro. The 8 pin connector on the back of the head unit for the sub amps now only has one wire for the mute of the door sub amp. I had tapped the shaker 1000 I bought on ebay into the + and - feed to the front door subs on this connector which are now not there and now I don't know how ford is feeding the pre-amp signal to the door sub amp.
Thanks for any help, Tom
Grandpa 05-08-2013 04:12 PM
Here is the 11/12 - http://iihs.net/fsm/?dir=710&viewfile=130
I cant imagine they are different for 13, but I will keep looking.
svostang 05-08-2013 05:07 PM
Thanks, that's the diagram I used to cable up in my 2012. It looks like they changed it for the shaker pro's in 2013/14. In that diagram the C290D/B connector pins 1 & 2 are the + and - and 4 is the mute circuit for the door sub amp. 5, 6 and 8 are the +, - and mute for the shaker amp. When I removed the head unit on my 14 that connector now only has a wire in pin 1 which is a 5volt feed I assume is for the mute on the door subs.
I searched every forum and googled my brains out trying to find it and all the online places like alldata only go upto 2012.
