2005-2012 Ford Mustang Front Wheel Bearing & Hub Assembly Pair
CHECK US OUT HERE FOR GREAT PRICES 2005-2012 Ford Mustang Front Wheel Bearing & Hub Assembly Pair
FREE SHIPPING IN THE LOWER 48 STATES!!! http://static.1aautoimages.com/parti...00467/main.JPG These replacement hub & bearing assemblies are just what you need to get your vehicle in good working order again. Specifications: Comes as a PAIR Fits both LH (Driver Side) & RH (Passenger Side) FRONT Replaces dealer part numbers: 4R3Z-1104-AA, 4R3Z-1104-AB, 4R3Z1104AA, 4R3Z1104AB Direct replacements New studs already installed Built to strict quality control standards Fits models with or without ABS For Non ABS Models, tone ring may be removed if needed Quality You will not have a problem with our product. If you are comparing us to someone selling a brand name product remember brand names are only as good as the company selling them. Both Bizrate.com and The Better Business Bureau recognize 1A Auto as a trusted online seller. You will be pleased with what you find out about us. You don't want to be delayed by a defective part. 1A Auto wheel hubs & bearings are all tested prior to shipping. Fit Guaranteed These hub & bearing sets will install just as your originals do. You can use your existing hardware. Save time and money with direct fit hub bearing assemblies. No trips to the auto parts store or extra time trying to match up and press bearings. Hub installation is a degree more difficult than changing a tire on most vehicles. Value Some shops and dealers charge more for parts and repairs when they think the customer doesn't know what is involved. Now you can get the value you deserve. Knowing what this repair entails can be the difference between the value of doing it yourself, or the pain of a costly part or repair bill. 2 Year Warranty This item is backed by a 2 Year Manufacturers Warranty. In the event this item should fail during intended use, we will replace the part free of charge (excludes shipping charges) for the original purchaser. Please keep your invoice for proof of this warranty. |
