-   -   has anyone tried pulling fuse 47 on the AT cars? (http://www.dfw50s.com/showthread.php?t=197)
SNEAKY 08-02-2012 07:39 PM
i was reading and it seems to make the automatics shift crisper.
PLASMAN 08-02-2012 09:23 PM
So does a tune. I wouldnt pull fuses to disable something that you know nothing about, easy way to cause damage to a great tranny
SNEAKY 08-02-2012 09:56 PM
you pull it for about 10 min and reinstall it. it is supposed to reset the adaptive learn for the transmission
Courtesy Flush 08-03-2012 11:06 AM
As stated crisper shifts would come from a tune. Pulling and resetting a specific fuse isn't going to do anything.
SNEAKY 08-03-2012 01:55 PM
I will let you know. I have read in four different forums that it does, so we will see
Phuck Phace 08-03-2012 02:10 PM
I've heard you have to do it quite often too, best to get a tune.
SNEAKY 08-03-2012 02:41 PM
Its the wives daily driver, so it would ve a track only thing. I am happy with power it makes. I just think there is some to be gained from a better shifting transmission.
PLASMAN 08-03-2012 11:35 PM
Taking the negative battery terminal off for a minute does the same thing to reset adaptive learning in the tranny and ECM
