-   -   Problem Starting this Morning (http://www.dfw50s.com/showthread.php?t=2050)
Dominic Toretto 06-24-2013 09:06 AM
Car is an automatic. Turned the key and the interior lights started slickering(dash lights, center console etc), and heard clicking as if the alternator was going bad. Turned it two more times and then it started. Now for the weird part, when I drove it, the transmission seemed to be stuck in "3" not drive but the stick was clearly in the "D" position. Double checked that several times. So while on the street the rpms were stuck between 1500 and 2000 depending on how much gas I was giving it. So I drove it back home. Turned it off and then restarted, put it in "D" and it drove fine. Anyone have any issues like this before?
Sorry meant to add car stats:
2012 GT Automatic
36,700 miles
No mods except axle back exhaust.
thelandshark 06-24-2013 09:49 AM
Ford had adaptive learning transmissions they learn how u drive and will do weird things when in this mode u prob have a bad battery and that will cause the trans to act up as its computer controled
Dominic Toretto 06-24-2013 10:02 AM
I hope the battery isn't going bad but, I have wanted to put a Yellow Top in the car. Would like to learn more about the adaptive transmission. Any good sources you know with links?
thelandshark 06-24-2013 10:46 AM
Not sure I work for ford that's how I know but I will look an see what I can.find
Dominic Toretto 06-24-2013 10:58 AM
Thank you. I found this on another forum by a google search. Pretty informational.
http://www.allfordmustangs.com/forum...iver-only.html
