-   -   Rear diff leak (http://www.dfw50s.com/showthread.php?t=247)
virtu 08-21-2012 05:39 PM
Rear diff leak
Noticed a little bit of fluid on the rear diff earlier today. No stains on the garage floor so I don't think its much. I've been researching and it appears to be a pretty common problem with 2005-2013 Mustangs. I have read it is the vent tube that is spilling out fluid during hard acceleration and/or cornering. Factory may have overfilled the diff? Some said to unscrew the drain plug and let it out til it stops. I believe factory spec says to fill 1/8" below the drain hole but I need to reconfirm that with the manual.
Have any of you experienced this? I will get underneath the car later and see if I can find exactly where it is coming from.
Phuck Phace 08-21-2012 05:42 PM
Yes
DirtyD 08-21-2012 05:49 PM
Just spill over from the diff as the fluid heats up and expands...
http://www.mustang50magazine.com/tec...xle_reservoir/
PLASMAN 08-21-2012 10:56 PM
Yes
Toby 08-30-2012 12:12 AM
Yes very common with the newer cars. I believe shelby makes a catch can for the rear diffs to help alleviate this problem.
