-   -   Exhaust leak (http://www.dfw50s.com/showthread.php?t=3302)
Le5oh 12-16-2013 02:06 AM
Exhaust leak
No matter which way i turn and tighten the factory exhaust clamps on my x pipe. It still contuines to have a leak. Any exhaust clamps recommended other then factory?
fordplay 12-16-2013 08:38 AM
High temp rtv .. or they make large band clamps that many people have said work well
lolvtec 12-16-2013 11:26 AM
Honestly a forum member gave me a pro tip. Rather than messy rtv silicone you can go to autozone or oreillys and get aluminum looking exhaust repair tape.. just wrap the joint and then clamp over the tape. Completely solved my leak issues.
Slowstang1_jgw 12-16-2013 03:17 PM
Did you cut the tabs so you can move them around?
I had the same problem, but turned the clamps around.
fordplay 12-17-2013 08:14 AM
I like the tape idea better than silicone, never thought of that. And better looking than the giant band clamps
DirtyD 12-17-2013 10:37 AM
I just installed 3 3" band clamps on my H-pipe last night. All 3 are leaking now after being tightened down all the way.
So I'm just going to have to either weld the cat deletes to the H-pipe, which I really don't want to do in order to keep the system modular.
But I will get the middle crossover of the H-pipe welded together.
Le5oh 12-17-2013 04:40 PM
DirtyD, That sucks.... I miss the days of 2 exhaust flanges welded on, a gasket and 2 or 3 bolts...
DirtyD 12-17-2013 04:54 PM
It happens. I wanted to get it put on, but I probably should've waited longer to line up someone to weld it up after install. Oh well. Live and learn.
Dan12GT 12-19-2013 11:33 AM
Ya I am wonder what kinda of head aches I will run into with the BBK deletes when I put them on. I was definitely considering 3" band clamps at a minimum.
Curious now that I look at it. Were the band clamps 3" in diameter or length?
Dan12GT 12-19-2013 11:39 AM
This is what I was looking at putting on since my piping is 2.75" from the cats back.
http://www.borla.com/products/275_st...rt__18005.html
DirtyD 12-19-2013 11:57 AM
Those BBK deletes are going to suck to even begin with...just FYI. lol
The clamps were 3" diameter when rolled and tightened. I'm going to pick up some exhaust tape to wrap around the cat to mid-pipe connection then put the clamps back over it. Then I'll have the mid-pipe welded at the crossover.
Dan12GT 12-19-2013 12:00 PM
Ya, I got them for $25 so if they don't work oh well.
Toby 12-19-2013 02:12 PM
Anyone needing something welded up, give us a call at truestreet. We can mig or tig weld it together no problem.
DirtyD 12-19-2013 03:18 PM
If you were so fast away, I would definitely make the trip up there. Been wanting to get the car back on the dyno just out of curiosity as well.
What time do y'all open Saturday?
