We now carry Spec Clutches!
If your Mustang clutch is chattering, slipping, or burnt up, a Spec clutch and flywheel is the perfect replacement. Whether you have a Fox Body, SN-95, New Edge, or S197 Mustang, these Spec clutches and flywheels can have you back on the road with a stronger and more reliable setup. These kits are offered in Stage 1, Stage 2, Stage 3, and Stage 3+ options to give you the best performance for your high horsepower 1986-2014 Mustang. Included in these clutch kits are a new clutch, pressure plate, pilot bearing, clutch aligning tool, and a new throwout bearing to make your clutch install quicker and easier. Don't forget to pick up a new aluminum flywheel to replace a warped or worn out flywheel! These aluminum flywheels are lighter than stock flywheels to reduce rotational mass and free up horsepower.
click the banner below to check them out: http://1115795f3e80f37d130b-0f74453f...tches_7723.jpg |
