Anyone else's auto shifter loose?
I have a 2011 auto and my shift handle is wobbly as can be. Anyone else having the same problem? and do any of y'all know how to fix it?
I haven't noticed mine being any more/less loose than any other auto car I've had. I really don't pay attention. I'll go check on brake and report back.
My knob wiggles from time to time.
:favorites37: |
Don't know about wiggling knobs, but my shifter assembly started making a very annoying sympathetic vibration during acceleration. The dealer replaced the entire assembly inside the tunnel under warranty.
They didn't tell you that the tune or the lca's were the cause? Trolol. |
No loose shifter here.
4 Attachment(s)
Thats wired i guess its only mine.. I did more research and found how to fix it. Ill post the pictures and some instructions, for anyone else that may have the same problem. :cheers:
Attachment 1295 Disconnect the Transmission Control Switch (TCS) electrical connector. Attachment 1294 Using a suitable tool, carefully pry the selector lever knob shroud down. Attachment 1292 With the selector lever knob shroud down, remove the 2 selector lever knob screws. Attachment 1293 Remove the selector lever knob and shroud from the selector shaft. |
