NTAXS Autocross #4, 7/12, TMS Bus Lot
North Texas Autocross Series (NTAXS)
Saturday, July 12th Texas Motor Speedway Bus Lot in Fort Worth, TX $40/driver entry fee. Pre-register at http://www.dlbracing.com starting June 27th. No on-site registration. The event is limited to 65 drivers. You get eight runs at NTAXS events, so you will make four runs in the AM session and four runs in the PM session, with a lunch break in between. 8 AM – 9 AM Check-in, Registration, and mandatory Tech Inspection (You must arrive in time to check in and pass tech inspection prior to 9 AM) 8:00 AM – 9:30 AM Course open for walking 8:45 AM Novice Meeting (mandatory if new to NTAXS events) 9:00 AM Drivers Meeting (mandatory for all) 9:15 AM First car out Car Classing is based on engine size: - Class 1/1R is for engines under 2.3 liters, except Honda S2000 and Lotus Elise/Exige. - Class 2/2R is for engines over 2.2 liters, but under 4.0 liters, plus Honda S2000. - Class 3/3R is for engines over 3.9 liters, plus Lotus Elise/Exige. - Class S2000 is only for Honda S2000 on street tires. - Class X/XR is an open class for any engine displacement and induction. Rotary engine multiplies displacement by 2.0. Usage of forced induction multiplies displacement by 1.5. (This is in addition to the rotary multiplier, if applicable.) Tires with a wear rating under 140 must use the R class. View the rules and additional information at http://www.ntaxs.com . Contact me at northtexasautocrossseries at yahoo dot com for more information. Find us on Facebook at http://www.facebook.com/ntaxs . |
Note that we are starting the event 30 minutes earlier than usual in anticipation or hotter temperatures. The drivers meeting is moved up from 9:30 to 9:00, so don't be late.
