-   -   347 stroker for new 5.0 (http://www.dfw50s.com/showthread.php?t=554)
BLK2012GT 10-18-2012 09:41 PM
This might be a dumbass question but does anyone offer a kit or can it even be done?
TrueStreetMotorSports.com 10-18-2012 09:56 PM
Not that big, pretty sure 322 is about as big as you can go. But if you are up for it we should drop a truck 6.2 in your car, no need for a stroker then :High 5:
Toby 10-18-2012 10:20 PM
wont work, the 6.2's have two plugs per cylinder with 2 coils that fire separately.
No need for the added ci. Just throw a blower on there and be done.
downtime! 10-18-2012 10:46 PM
327 ci was the limit on 3V, I imagine that's about it for this one as well. Cams and a blower will satisfy your need. That old adage about no replacement for displacement hasn't been true for many years.
46Tbird 10-22-2012 11:01 AM
Will the 5.0 cylinder heads bolt onto the 6.2 shortblock?
Toby 10-22-2012 09:45 PM
Yes that is possible. Although i am not sure what intake will line up. The 6.2 is a compete different breed. its a sohc with a shaft mounted rocker and inline valves. It has a large bore unlike the previous mod motors which unshrouds the valves allowing much better breathing without large ports thus keeping the intake velocity up and helping with fuel economy.
STROKD 10-23-2012 09:15 PM
Lawlz, srsly? A larger motor with equal boost will always make more power than a smaller one... Design'd equally of course. A 9k rpm blower car will obviously make more power than a larger cid turbo diesel done at 4k of course.
downtime! 10-24-2012 02:23 AM
Yes, Capt. Obvious, that is true, but that wasn't what I was saying now was it? I was merely pointing out that he didn't need to add c.i. to get the power levels we used to have to use big inch motors for. Now that tuning almost any combination is possible, large engines aren't needed to achieve insane power levels. But I also see that you're quite a bit younger than I am, so you likely don't remember those times. Thanks for playing though, we have some nice parting gifts for you backstage.
STROKD 10-24-2012 05:51 PM
Lmao, ok, my fault, I have no idea wtf I'm talking about...I've never had a car as magically fast as yours is..
What parting gifts did I win?
Grandpa 10-24-2012 06:08 PM
Strokd doesn't know what he's talking about when it comes to FPS games. He sucks! Cars, a lil different story. lol.
downtime! 10-24-2012 06:54 PM
No you didn't know what I was talking about. It wasn't about small cube blower motors versus large cube blower motors. It was comparing a larger cube n/a motor to a std cube blower motor. Simple as that. And this is the slowest car I've owned in years. Again, making assumptions is not your strong suit.
STROKD 10-24-2012 10:52 PM
Don't need to make assumptions. I wasn't talking about a na big cid motor vs a smaller blown motor, because I'm not into NA and being slow. A larger cid motor with boost making the same power as a smaller motor needing more boost will be faster. I guess I shouldn't have quoted you to get you all ruffled, since it seems to really bother you with what I said and it wasn't exactly your point. Not sure why anyone would spend money for a bigger motor and not boost it. Have a friend with a 760bhp 445 lsx, and he's slower than anyone I hang with because he won't put a damn power adder on it.
Yes a blown 5.0 will beat a 347 or 408 NA, but my point was a blown stroker would torch a blown 5.0. Sorry if I derailed your point.
downtime! 10-24-2012 11:14 PM
Not ruffled at all, just pointing out that in the context of what I was talking about, you interjected a viewpoint that was totally irrelevant. I'm a boost fan as well these days, not sure why anyone wouldn't boost anything.
Phuck Phace 10-25-2012 12:10 AM
I like bewst!
11bangbang 10-25-2012 12:32 AM
Originally Posted by Phuck Phace (Post 8626)
I like bewst!
same, and beer...
