-   -   Cylinder #3 Misfire P0303 code (http://www.dfw50s.com/showthread.php?t=782)
Slow6 12-13-2012 10:31 AM
Well I got the car back from True Street this last Saturday and it was throwing a P0303 code. Cylinder #3 misfire. So Toby changed out the plugs real quick and cleared the code. About twenty miles later the code came back. Im going to swap the CAP on #3 with another cylinder and hope the code follows. If that doesnt work I'll swap the injectors the same way. My last option is a crank sensor relearn at the dealership. Sounds like this may be the problem to begin with but I just want to check the CAPs and injectors first.
Apparently misfires are read by the crank position sensor and if you break into the engine then you have to perform this relearn process. Im hoping I dont have to go to the dealer but if it fixes it I guess I'll be happy. I just need to get it figured out before next week so we can finish tuning the car.
Grandpa 12-13-2012 12:12 PM
That's hot rods. There is always something. Hope you get it worked out.
