Old 06-14-2013, 07:18 AM   #1
fordplay
Default cat less
OK who has removed their cats here? Question, when you go for inspection do you have to put your cats back on or do they just plug in the obd2 ?
fordplay is offline   Reply With Quote
Old 06-14-2013, 07:26 AM   #2
Luke
Luke's Avatar
The tune will take care of the light and obd2, but if they physically look you will fail. Worst case, if you go in and fail and they charge you, you can throw them back on and don't have to pay again as long as it's within 15 days.
Luke is offline   Reply With Quote
Old 06-14-2013, 03:46 PM   #3
fordplay
Boo.. but has anyone been busted by this? They don't use a sniffer right?
Old 06-14-2013, 04:17 PM   #4
01BeansGt
This^
Anything from 89 to 95 they use the sniffer. 96 and up just the ob2.
01BeansGt is offline   Reply With Quote
Old 06-14-2013, 04:29 PM   #5
Oxford14Stang
Oxford14Stang's Avatar
All information above is correct. I'm a state inspector and we are suppose to check for cats during our inspection. Given there are plently of shops that do not do their job and check for them. As long as no check engine light is on I'd sy your nearly 80% in the will pass and maybe 20% that an actual inspector would check and fail you.
2014 Oxford White 5.0 MT-82
Oxford14Stang is offline   Reply With Quote
Old 06-14-2013, 04:46 PM   #6
JDMLOL
JDMLOL's Avatar
Default Re: cat less
Aftermarket tunes that tune out the cats will show not ready on system readiness monitors. You can have one "not ready" and still pass. It's funny, ive heard these cars will pass a sniffer even without cats. Ive never had anyone do a visual on my inspections, I usually sit out and watch. Not to say they arent supposed to look underneath....
Old 06-14-2013, 06:35 PM   #7
slim87gt
True True. If you have an offroad on the 2005 and up it will not pass inspection visually or by the OBD2
Besides the cats dont rob that much power
slim87gt is offline   Reply With Quote
Old 06-14-2013, 06:57 PM   #8
svt-eric
svt-eric's Avatar
no cats on my cobra. just got my inspection done a couple weeks ago and it passed.
svt-eric is offline   Reply With Quote
Old 06-14-2013, 07:06 PM   #9
You will indeed pass if its tuned for it. I have had issues with my previous mustang where I took it in and they knew it had exhaust and put it on the drive on lift to check. That only happened one time though. Most like mentioned earlier will not bother to check if the light isn't on.
Old 06-14-2013, 07:17 PM   #10
Selcouth
Selcouth's Avatar
Simple way around that. Purchase a catalytic converter that has a straight pipe running through it.
Has the looks of a catalytic converter, but its technically not.
Selcouth is offline   Reply With Quote
Old 06-15-2013, 05:36 AM   #11
Luke
Luke's Avatar
15rwhp is what vendors are claiming for o/r pipes, even if that's a little on the high side that's cheap horsepower.
Old 06-15-2013, 07:46 AM   #12
04sleeper
King of the Multi-quotes
Not if you know what you are doing.
04sleeper is offline   Reply With Quote
Old 06-15-2013, 11:02 AM   #13
JDMLOL
JDMLOL's Avatar
This.
You could always fab up some heat shields or run gutted ones.
Old 06-19-2013, 07:39 AM   #14
fordplay
Svt performance actually did a test on the 2011 gt and 19 horse is gained on the dyno by killing the cats.. I'm sorry the the best bang for the buck there is. Wait I just looked that's 19 with an X pipe the H pipe is 3 less.. still a bargain ... all I need is a take off set of gt500 mufflers.. someone can have my flow master axle back as trade!! Ha ha
Old 06-19-2013, 10:07 AM   #15
Smurf50
Smurf50's Avatar
From many years of car modding and inspection experience, this is correct. There are also certain times that you can go in where they are less apt to check under the car than others (specifically when the managers aren't standing over them because they are busy).
This is why I am considering getting the high-flow catted X-pipe for my car when I do headers. There shouldn't be THAT much of a loss compared to catless, and no inspection worries.
Smurf50 is offline   Reply With Quote
