Go Back   Dallas Fort Worth 5.0 Mustang Club > Photos & Videos > Other Makes and Models
Other Makes and Models Section for people who don't have 5.0s but still have badass cars. DFW 5.0s Welcomes everyone
Old 10-20-2013, 07:29 PM   #1
Only 1000 laguna were ever produced. Its just funny to me that they compare it to a LRA car. Lol
Old 10-20-2013, 07:44 PM   #2
Dominic Toretto
Dominic Toretto's Avatar
Camaros and Mustangs have been direct competitors for decades.
Old 10-20-2013, 08:42 PM   #3
Im waiting for the new stangs to cone out. Its gna be 600lbs lighter. Weight is everything.
Old 10-20-2013, 10:39 PM   #4
Dominic Toretto
From Chevrolet.com
SACRIFICE ALL IN THE NAME OF PERFORMANCE.
The legendary Camaro Z/28 is back for the 2014 model year. Originally introduced in 1967, Camaro Z/28 was designed specifically to compete in the Sports Car Club of America's Trans-Am 2 class. Lightweight, nimble and incredibly powerful, the original Z/28 was designed ideally for road racing. The 2014 Z/28 carries the same racing credentials, running a lap around the Nürburgring track with an impressive 7:37.40 time in inclement weather.
POWERTRAIN
A hand-assembled LS7 engine powers the Camaro Z/28, boasting an incredible 505 horsepower and 481 lb.-ft. of torque, making it the most powerful normally aspirated regular production small block V8 ever. The highest-quality parts and precision assembly elevate the redline level to 7000 rpm.
Durable, lightweight components such as titanium intake valves and connecting rods coupled with a forged-steel crankshaft make the LS7 engine incredibly robust. The standard 10.5-quart, dry-sump oil system distributes pressurized oil from an external reservoir to protect vital components under high-g driving conditions.
The LS7 is mated to a TREMEC® TR6060 6-speed manual gearbox that features close-ratio gearing - optimized for the engine’s power characteristics. The TREMEC is coupled with a 5.1:1-ratio short-throw shifter to ensure quick and precise shifts
Power is distributed to the rear wheels via a limited-slip differential, which features a helical gear set rather than traditional clutch packs that continuously adjusts torque bias allowing drivers to confidently lay down more power to get through corners faster. Coupled with the Performance Traction Management (PTM) system, drivers can adjust the level of throttle and brake intervention to match their capability and driving environment, essentially making PTM custom to each driving situation.
Z/28 features a cooling system designed for the track — standard. This incorporates the dry-sump oil system of the LS7, which connects to an integral liquid-to-liquid cooling system for engine oil. Another liquid-to-liquid system provides cooling for the transmission and differential.
BODY
The 2014 Camaro Z/28 pays homage to the exterior of the original legend while capitalizing on 21st century design elements and technology. Z/28 was born to be a functional instrument for the track, utilizing best practices and influences learned through racing.
Camaro Z/28 has aerodynamic treatments designed to produce downforce — specifically at track speeds. A large splitter connects to an underbody panel to further reduce lift. Fender flares over the front and rear wheels and extended rocker panels contribute to aerodynamic stability. Z/28 also features an aggressive rear spoiler and functional diffuser to complete the fully integrated aerodynamic package.
CHASSIS
The tires on Camaro Z/28 are robust and massive Pirelli® PZERO™ Trofeo R† 305/30ZR19 summer-only tires† — ideal for lateral motions, like corner entry and exit.
Camaro Z/28 features lightweight Brembo® carbon Ceramic Matrix™ rotors and fixed, monoblock calipers. The huge 394 x 36 mm front rotors are paired with 6-piston calipers, while the 390 x 32 mm rear rotors are paired with 4-piston calipers. Compared to similar-size two-piece steel rotors, the lightweight and large carbon calipers save 22 pounds, while encouraging impressive stopping power and heat toleration — ideal for track use.
Camaro Z/28 is one of the first production cars to feature race-proven spool-valve dampers. The spool-valve damper allows 4-way adjustment to precisely tune both bump and rebound settings for high-speed and low-speed wheel motions. The wider tuning range dramatically increases the damper stiffness on Camaro Z/28 without significantly impacting ride quality.
INTERIOR
The all-new driver and front passenger racing seats are designed by RECARO®. Aggressive bolsters ensure both passenger and driver remain firmly planted, even in high-energy driving situations. A flat-bottom steering wheel opens leg room for entry and exit, as well as quicker heel/toe shifting. A short-throw shifter allow for rapid, confident shifting."
Old 10-20-2013, 10:43 PM   #5
Cant wait for that new all motor shelby. Then ford will own that as well lol.
Old 10-21-2013, 12:51 PM   #6
So basically what your saying is that the Z28 is the baddest street car in its price range? Im gna ask you this....How many people actually take their cars to the track. Not just people you know personally but in general. Very very few. Track Fees are alot more then Drag strip fees. Its nice to know it can circle the track in German in so many par secs but at the end of the day most people that buy these will use them on the street. If you run across a your buddy who just bought a new shelby for the same money your not gna say " follow me to the track".
Old 10-21-2013, 01:03 PM   #7
Dominic Toretto
I never claimed the Z/28 was the baddest car ever. I just posted this thread for people interested in the car. That was it. I'm a car enthusiast and like several types of cars, not just Fords. Plenty of people measure performance based on track times. If the Mustang went around a track faster than a Camaro, how many people here would have bashed the car?
Old 10-21-2013, 12:54 PM   #8
Fact of the matter is that GM beat a car with "outdated" technology, wider and track appropriate tires, and more power. Yay?
The SRA Boss LS ran all of it's times on streetable "R"-ish compound tires in a 255/285 setup.
Old 10-21-2013, 01:04 PM   #9
Dominic Toretto
Were you expecting them to beat the car using less power, technology from the 90s and winter tires?
Old 10-21-2013, 01:27 PM   #10
How many people here would be interested in that car? NOne would have bashed and none are bashing the car. We are just saying for the money there are better options as far as power and speed are concerned. Like I said earlier GM owes the Taxpayer a ton of money and they are making niche cars. Why?
The fact they had to use 305mm tires, a 7.0 liter engine and alot of other stuff speaks highyy of the boss to me.
Old 10-21-2013, 02:03 PM   #11
saunupe1911
saunupe1911's Avatar
I like the niche car thing because its pushing the entire industry.
I totally agree with the second comment. 305 all 4 corner, LS7, stripped down....I have seen all this before! It's nice performance car, but it's not impressive at all!!!
Now take the Boss LS with all the creature comforts, looks, exclusivity, and performance...that's impressive. And keep in mind that these LS owners will have been enjoying their car and bragging rights for 3 yrs come March 2014 (Z/28 expected shipments). And they are gearing up for the next gen Mustang in less 10 months from the Z/28 release.
saunupe1911 is offline   Reply With Quote
Old 10-21-2013, 02:36 PM   #12
Dominic Toretto
ROFL. Okay so the Z/28 can be had with the same creature comforts as a Boss, looks are subjective, going to also be exclusive and the performance kills a Boss 302 and that is NOT impressive!?
So exact same criteria but it's not impressive lol. You're sounding extremely hypocritical now. If you just don't like the Camaro, I would accept that answer. But since both cars have the same stats you like with the Boss, and deem it not impressive is just sounding trolling.
Old 10-21-2013, 02:30 PM   #13
Dominic Toretto
Who said they had to use an LS7, carbon brakes, or anything else to beat a Boss? If anything, it sounds like they wanted the car to humiliate a Boss. Like the Chief Engineer in the video said, they are aiming higher than a Mustang based on the list of cars he said he wants the Z28 to be mentioned with. And the fact that they are using top end Corvette materials just confirms it.
Old 10-21-2013, 03:18 PM   #14
What re-rv7 said, exactly.
Had Ford spent as much time and development on the Boss on top of the GT as GM did solely on the Z/28 over the SS, the Boss would most likely be able to hang with it damn near to the millisecond. I did read somewhere that GM originally planned to release the Z/28 in 2011, but unforeseen circumstances apparantly came about. Even then, the Z/28 uses an already in production engine, an already in production transmission, and already in production magnetic ride IRS, and new fancy R compound tires, which aren't street legal. So it's not like GM custom built this car, from the design board forward, specifically to race and beat the Boss. I think a lot of people see it as a built from scratch car, with everything made for the car, when it's not.
Old 10-21-2013, 03:25 PM   #15
Dominic Toretto
Very fair argument Derek. That is a plus to the Boss 302, everything was built specifically for that car. The Z/28 does use leftover ZO6 and ZR1 parts. I think the only new parts are the aero.
