If you want to customize your Mustang and fit it with a set of trending overfenders, you can easily achieve this goal with help of a new Wide Body Kit from Clinched Flares. Made out of ABS plastic utilizing CNC-cut molds to ensure a top quality fit and finish, it looks like a proper blend between a race and a street car. This kit not only changes the appearance of your Mustang but also improves it's performance capability since it allows you to run a much more aggressive wheel and tire combo.
Clinched Flares® - Wide Body Kit (Unpainted)
![](https://www.carid.com/images/for-forums/clinched-flares-kit-must-2.jpg)
![](https://www.carid.com/images/for-forums/clinched-flares-kit-must-1.jpg)
![](https://www.carid.com/images/for-forums/clinched-flares-kit-must-3.jpg)
Features:
- Includes: front and rear fender flares, front add-on lip, front bumper flares, side skirts
- Impact-resistant construction won’t crack or peel
- Built to ensure many years of faithful service
- Allows you to run a much more aggressive wheel and tire combo thus helping you put all that mighty power to the ground
- Constructed using industry-leading materials to ensure the highest endurance and longest lifespan
- You will be required to cut your existing fenders and quarter panels
- The kit does not come with mounting hardware or rubber gaskets (sold separately).
Clinched Flares™ | Fender Flares, Body Kits, Hood Vents — CARiD.com
What are your thoughts about this body kit? Let us know in the comment section below!
