Old 11-13-2013, 05:48 PM   #1
modernbeat
modernbeat's Avatar
Don't worry about the color. The plate is almost entirely hidden inside the strut tower.
If you really want to compete in Autocross, first choose a class. That parts list you chose will put you into SCCA C-Prepared where you will be up against gutted tubs on racing slicks, not DOT-R Hoosiers.
My recommendation would be to look at either E-Street Prepared, or Street Mod if you are going to be doing internal engine mods.
As far as suspension goes, I'd use Motion Control TT2 dampers and our Vorshlag camber plates, Whiteline Watts, and depending on the class, either an upper arm (ESP) or lower arms and relocation brackets (SM). I'd add Whiteline front and rear adjustable bars and end links and then stick 18x11 wheels front and rear with 315/30-18 Hoosiers.
Jason McDaniel at Vorshlag Motorsports
modernbeat is offline   Reply With Quote
