Old 08-07-2013, 11:19 PM   #1
JDMLOL
JDMLOL's Avatar
Default Rev matching
How do you do it? Blip in the desired gear with the clutch in or in nuetral on the way to the desired gear? I've always done it with the clutch in, read somewhere that someone did it nuetral. Im not coordinated enough to blip in nuetral on the way to the desired gear, it's hard enough doing it with the clutch in. Does it matter?
Old 08-08-2013, 12:00 AM   #2
JDBishopArts
JDBishopArts's Avatar
Doesn't matter. Stop playing fast and furious.
Old 08-08-2013, 12:23 AM   #3
Downshifting I blip the throttle with my right side of my right right fool while applying brake pressure while on my way to the desired gear. Basically clutch->blip-> gear while braking. It takes some practice but it gets easier.
Old 08-08-2013, 12:55 AM   #4
JDMLOL
JDMLOL's Avatar
Lol.
I will never be able to heel toe. Too many things to do at once.
Old 08-08-2013, 01:17 PM   #5
Take practice. It's 2nd nature to me now.
Old 08-08-2013, 02:27 PM   #6
Dan12GT
Dan12GT's Avatar
I do this a lot while downshifting so it doesn't shock the tranny. I usually blip it with the clutch pushed in right before I move it down a gear.
Old 08-08-2013, 02:41 PM   #7
I do what Danny said. Blip the throttle to get within so many RPMs of where I'm going to be downshifting, while the clutch is in, and I will put it in gear and release the clutch before the RPMs fall again. Sometimes it goes smoother than others.
Old 08-08-2013, 02:48 PM   #8
Rebelracer568
Rebelracer568's Avatar
Just keep foot on edge ofbrake and roll your ankle to throttle to get in rpm range you desire.
Rebelracer568 is offline   Reply With Quote
Old 08-08-2013, 04:39 PM   #9
KungFuHamster
KungFuHamster's Avatar
whats the point in doing this?
2011 Mustang GT Grabber Blue
KungFuHamster is offline   Reply With Quote
Old 08-08-2013, 04:44 PM   #10
JDMLOL
JDMLOL's Avatar
Smooth downshifts that put less wear on the clutch?
Old 08-08-2013, 04:48 PM   #11
KungFuHamster
I see. Well I granny shift and don't double clutch like I should.
Old 08-08-2013, 04:54 PM   #12
BhowardB
BhowardB's Avatar
Double clutching is for unsynchronized transmissions
BhowardB is offline   Reply With Quote
Old 08-08-2013, 06:15 PM   #13
El_Tortuga
El_Tortuga's Avatar
In road racing, not to induce any uncontrolled braking nor sudden weight transfer. Done right, its one of the joys of driving stick.
Old 08-08-2013, 07:09 PM   #14
JDMLOL
JDMLOL's Avatar
I guess you were lucky you didn't blow the welds on the intake too, huh?
Old 08-08-2013, 10:57 PM   #15
my95z28
my95z28's Avatar
Rev matching with it in gear will save wear on the clutch. Rev matching in neutral to get it into gear will save syncros
my95z28 is offline   Reply With Quote
