Old 07-27-2012, 03:59 PM   #1
Default Post your Suspension mods
Heres a thread dedicated to your suspension. Post all the mods you have done and how you like it, etc.
Im running Koni STR.Ts struts and shocks with steeda sport springs. Ride height is perfect for me and the ride quality is better than stock!
Old 07-28-2012, 08:26 PM   #2
Eibach Sportline springs
Koni Sport (Yellow) shocks and struts
Fays 2 Watts Link
Eibach front and rear swaybars
Steeda bumpsteer kit
Maximum Motorsports caster/camber plates
Billet lower control arms
BMR LCA relocation brackets
Sits low, looks good, rides a little bumpy now but that's okay because racecar.
Old 07-30-2012, 07:16 PM   #3
kanetrain
kanetrain's Avatar
Eibach coil-overs, rear LCAs, adjustable panhard bar. That's it so far.
Eibach coil over kit, adjustable panhard bar w/ rear LCAs, Hurst shifter, magnaflow cat-back exhaust, o/r x-pipe, 85mm tb, cai, tune, 3.73 rear end gears, gold plated cross drilled/slotted rotors, TSW 19inch wheels, nice big 305s on the rear.
kanetrain is offline   Reply With Quote
Old 09-16-2012, 12:32 PM   #4
89gt-stanger
BMR LCA's
BMR relos
UPR dbl adj. UCA
UPR dbl adj. Panhard
89gt-stanger is offline   Reply With Quote
Old 10-05-2012, 08:13 PM   #5
Cabikejumper
Eibach sportlines with isos removed
SVE upper and lower control arms
2010 GT500. L&M cams, VMP 2.5, lethal ORX, Corsa extremes.
2005 GTO. 403ci twin turbo, E85
2012 dodge ram 3500. Slow and Stock
Cabikejumper is offline   Reply With Quote
Old 10-09-2012, 12:10 AM   #6
OG Fox
OG Fox's Avatar
Eibach Pro Springs
Eibach Pro Struts/Shocks
Eibach Front/Rear sway bars
Maximum Motorsports Caster/Camber Plates
Maximum Motorsports Adj. Panhard Bar
J&M extreme lower control arms
BMR adj Upper Control arm with mount
BMR LCA relocation Brackets
Steeda Bumpsteer & balljoints
Old 10-09-2012, 09:02 AM   #7
HOLYWD
HOLYWD's Avatar
D2 Coiliver Kit with built in C&C plates
Spohn front and rear adj. sway bars
BMR adj. panhard bar
J&M lower control arms
BMR LCA relo brackets
2012 Mustang 5.0
HOLYWD is offline   Reply With Quote
Old 10-09-2012, 08:01 PM   #8
jayman33
I ride on stuff that gives me back problems.
www.hypermotiveperformance.com
734-306-5231
jayman33 is offline   Reply With Quote
Old 10-11-2012, 12:59 PM   #9
OG Fox
OG Fox's Avatar
oh you like it stiff huh?
Old 10-11-2012, 03:45 PM   #10
jayman33
Oh you nasty girl!!
734-306-5231
Old 10-28-2012, 12:30 PM   #11
YUP! lol
Old 11-01-2012, 02:28 PM   #12
finally installed my d2 coilovers. love the look and the ride is good.
Old 11-01-2012, 06:03 PM   #13
jayman33
Much better homey, coilovers was a good decision. The overall pacakge of your car looks much better!!
734-306-5231
Old 11-01-2012, 06:13 PM   #14
shadow11
Looks good Nick!
shadow11 is offline   Reply With Quote
Old 11-09-2012, 11:20 PM   #15
maxpayne
Wow. Sick.
maxpayne is offline   Reply With Quote
