Old 08-23-2013, 07:43 PM   #1
5HIFT3D
Default Hi Temp Paint
I was just trying to figure out if any of yall out there has painted or powder coated your exhaust? What did you use and how did it turn out? Thanks for the info, new here by the way. Pics and tips if you gotem to spare.
5HIFT3D is offline   Reply With Quote
Old 08-23-2013, 08:05 PM   #2
Nay
search exhaust in the search box, i believe someone started a thread on that with some pics.
Nay is offline   Reply With Quote
Old 08-23-2013, 08:08 PM   #3
5HIFT3D
Appreciate ya!
Old 08-23-2013, 08:10 PM   #4
BV600
I used VHT hi temp Ill take a picture of the can if you want. heres a couple pics
BV600 is offline   Reply With Quote
Old 08-23-2013, 08:34 PM   #5
5HIFT3D
Looks good, I looked online at a spot called endure coatings in mesquite and they actually had some color on an exhaust setup. all the way from the cat to the tip, looked pretty sick. I know it is just an exhaust and nobody will see it but if my car wasn't black and I was going for a color scheme besides jet black all the way thru I'd do this. I want the bugs to say "DAAAAAAMMMMMMNNNNNN" when I roll overem. Appreciate your help, did you use scotch brite or a certain grit sand before you put on the coating?
Old 08-23-2013, 08:41 PM   #6
BV600
nope simple green to clean them then maybe 4 coats then drove it to bake it on
Old 08-23-2013, 08:56 PM   #7
5HIFT3D
Do you know if LineX will hold up in those temps? Might sound like a dumb question but I have to ask.
Old 08-23-2013, 09:54 PM   #8
Just get some rattle can vht. I promise mufflers won't get near hot enough.
Old 08-25-2013, 06:38 PM   #9
El_Tortuga
El_Tortuga's Avatar
VHT for me.
Looks great and no issues 6 months later. I only wish I had painted them before they went on the car.
Old 08-25-2013, 11:31 PM   #10
Dan12GT
Dan12GT's Avatar
Ya the mufflers won't get near as hot and should hold up with some high temp paint no problem. I would just afraid of it chipping from debris kicking up being only a paint under the car.
Old 08-26-2013, 12:24 PM   #11
BlueBolt
VHT here also. If it chips where you can see it just touch it up.
BlueBolt is offline   Reply With Quote
Old 08-26-2013, 12:34 PM   #12
Vht my old gt500 does the job
Old 08-30-2013, 02:43 PM   #13
Mdelongpre
Mdelongpre's Avatar
+1 on vht, i used it on my roush mufflers and tips
http://i50.tinypic.com/16gkd4.jpg
Mdelongpre is offline   Reply With Quote
Old 09-13-2013, 11:38 AM   #14
Used Plasti-dip 2 weeks ago. Still going strong.
Old 09-17-2013, 09:46 PM   #15
brembo12
Thumbs up
Ford should have done it this way to begin with......good job! Nice work!!!
2012 Performance White BBP/MT82 GT 400A Lava Red/Charcoal more as it unfolds....
brembo12 is offline   Reply With Quote
