09-18-2013, 12:09 AM
Need help car failed the inspection twice !!!
No check engine light is on, battery hasn't been disconnected not sure if its a exhaust issue that's causing the car to fail. Here's the inspection sheet.
2011 A6 Kona Blue 5.0
09-18-2013, 01:59 AM
I'm assuming you have an off road x or h pipe? If so, then the rear O2's need to be turned off in the tune. That's what we had to do to get mine to pass.
09-18-2013, 07:56 AM
You can only have one not ready.
09-18-2013, 01:50 PM
Whoever is doing the calibration doesn't know how to turn all that off. Changing the value of just one scalar will make nearly every monitor shows N/S, and N/S counts the same as PASS.
NA 2011 GT Auto
[email protected]
Texas Mile - 152.8 half mile/180.0 mile
09-18-2013, 02:24 PM
From what I could tell when I met up with im the other day, it appears that he X pipe has high flow cats, so I think this may be part of the issues?...
09-18-2013, 02:28 PM
Very possible if they intentionally left all the monitors enabled, expecting it to work like stock, which it often doesn't.
NA 2011 GT Auto
[email protected]
09-18-2013, 02:33 PM
We are assuming you have an aftermarket tune? Do you? Or is it stock?
09-18-2013, 02:37 PM
I want to say I've heard other people having issues with with high flow cats and passing inspections.
He bought the car used, of which it was already tuned by Lonestar Performance.
09-18-2013, 03:51 PM
DirtyD is correct I bought the car 2 months ago the previous owner had all the mods and tune done by Lonestar performance (which I'm not happy with). Could that be fixed with the handheld programmer?
09-18-2013, 03:53 PM
Not something the end user can change on a handheld, you'll need a calibration with this stuff already turned off loaded onto the handheld, then flash the car with the new calibration.
NA 2011 GT Auto
[email protected]
09-18-2013, 03:58 PM
No. More than likely what is happening is the voltage on your 02's is still high enough for the car to be in not ready mode causing the code. That is something your tuner will have to fix for you.
09-18-2013, 04:11 PM
I see ,well I was planing on retuning it anyways, looks like its gonna be sooner than what I was expecting. Thanks guys
09-20-2013, 11:01 PM
#14
2012 Performance White BBP/MT82 GT 400A Lava Red/Charcoal more as it unfolds....
09-20-2013, 11:41 PM
#15
