09-22-2013, 09:40 PM
Installed STR.T/GT500 mounts/H&R Race
09-22-2013, 10:06 PM
Sweet! Looks awesome.
About how much that setup cost you?
2014 Ford Mustang GT (aka "Vivian") - M6 Stripper. Mods: Strut Tower Brace; Roush ABs; 18" by 10" SVE Drifts with 285 Nitto NT555s.
09-23-2013, 07:03 AM
80 for strut mounts
350 shocks/struts
150 springs
120 panhard bar
09-23-2013, 09:35 AM
A lowering does wonders for these cars in the look dept.
09-23-2013, 07:46 PM
Definetly Does, now I just need wheels and my hood vents back already.
09-23-2013, 11:59 PM
Looks sweet, are you planning to do control arms since its lowered?
09-24-2013, 09:22 AM
Yep sooner or later
09-24-2013, 11:09 AM
Needs to be sooner. And relocation brackets. Go BMR from Jayman.
09-24-2013, 11:42 AM
I've got a pair of BMR relocation brackets in the garage if you're interested.
09-24-2013, 12:23 PM
PM me what you want for them
09-24-2013, 01:38 PM
Recommend lca and relocation bracket def recommend put em on my car. Made world of difference
09-24-2013, 05:33 PM
Anyone have an idea of what to check? See below
Under nose dive braking and some bumps I get some slight noise, can feel it more than here it. I torqued everything to spec, unless the Nut on the actual struts isn't all the way tight. Used a 200 ft lb electric tq wrench and went back and checked the tq after.
09-24-2013, 05:36 PM
#13
You will get some noise here and there with aftermarket stuff. You did keep the ISO's on the springs right? Mine doesn't make much noise in the front but will if I hit it just right. Mostly, my noise comes from the rear sway I think. I need to check it.
09-24-2013, 06:17 PM
#14
Yep kept iso. My 2012 with bmr springs, steeda pro actions, and panhard made no noise.
09-24-2013, 06:25 PM
#15
Rattle, knock, squeak?
