Old 12-23-2013, 09:52 PM   #1
jng2985
jng2985's Avatar
Default Spring help
Ungodly noise from the rear end.. Lol. Any ways, crawled under to see wtf and saw my rear springs. Attached is I hope the passenger side. Driver side normal, passenger completely compressed and the car isn't slanted.
Wtf is it? And who wants to drink beers and help fix it.
jng2985 is offline   Reply With Quote
Old 12-23-2013, 09:55 PM   #2
jng2985
jng2985's Avatar
Passenger side
Old 12-23-2013, 09:59 PM   #3
That's odd...
Old 12-23-2013, 10:08 PM   #4
JDMLOL
JDMLOL's Avatar
Originally Posted by 03MachMe View Post
That's odd...
Very.
Type of springs?
Old 12-23-2013, 10:09 PM   #5
jng2985
jng2985's Avatar
Originally Posted by JDMLOL View Post
Very.
Type of springs?
Ford K, Lca's, panhard.
Old 12-23-2013, 11:27 PM   #6
either the spring came out of its area and is compressed on the side of it or something is stuck up there compressing the spring. Just jack the car up and remove the strut on that side with the axle supported and let it down slowly and see why it is not up in the area it is supposed to be.
Old 01-04-2014, 05:43 PM   #7
jng2985
jng2985's Avatar
Spring was upside down. Flipped it over, no more noise..
Old 01-04-2014, 08:08 PM   #8
zsommer79
So you had one right and one upside down? On the Ford springs they are stamped so you should be able to read ford when they are put in right. One of mine had a partial mistamp that was upside down but they had stamped it again the right way.
zsommer79 is offline   Reply With Quote
Old 01-04-2014, 09:07 PM   #9
jng2985
jng2985's Avatar
I originally had them installed and they put in f'd up.
Old 01-04-2014, 09:43 PM   #10
donutninja
donutninja's Avatar
So maybe I don't follow but why would the spring being upside down cause it to be fully compressed like that?
donutninja is offline   Reply With Quote
Old 01-04-2014, 10:16 PM   #11
jng2985
jng2985's Avatar
That's how it should be just flipped over. Coils start narrow and spread out, when installed correctly you can't see how compressed the spring is unless its jacked up. It was a mind fuck of a thing. Had no clue wtf happened and thinking worse case I picked up another set of K springs. Looking at the rear spring this morning it occurred to me that it's prob upside down.
The kicker is, either way the load on the spring is the same no matter how it is installed? What I found, no more noise/ride was improved.
Old 01-05-2014, 12:17 AM   #12
donutninja
donutninja's Avatar
yeah, crazy it can make such a big difference. At least you got it figured out!
Old 01-05-2014, 06:35 PM   #13
zsommer79
The load isn't the same because the angles the spring compress at are going to be affected. If you could have seen it compressed it probably had a bulge/arch in it. Have you checked the front to make sure the shop installed them correctly? If the strut mount isn't positioned correctly it will throw your angles off.
Old 01-08-2014, 09:27 AM   #14
Dan12GT
Dan12GT's Avatar
Ya I was about to say looks like the progressive coiled side of the spring is upside down. I'd defiantly re-check everything too.
Old 01-08-2014, 10:05 AM   #15
jng2985
jng2985's Avatar
All is is well on the other corners, now off to ford for axle leak and idle issue.
