03-06-2014, 12:36 AM
Drank the AED grape drink...
And it's AMAZING!
Installed my JBA Long Tubes and off-road H-pipe today with Shaun's AED tune and have been loving it! Hopefully I can get a video up in a couple of days.
Also, thanks to Austin at BA-speed for the hook-up on the JBA's.
03-06-2014, 12:53 AM
Now buy my cams
03-06-2014, 01:19 AM
I want those cams. Be perfect NA power, but I really don't want to crack into my motor. And I'm not sure of I'll lose any MPG, since the car is still a DD
03-06-2014, 01:32 AM
Haha. Not anytime soon. I'm broke.
2011 Kona Blue 5.0
03-07-2014, 01:30 AM
Originally Posted by mavfan37
And it's AMAZING!
Congrats. Shaun is a great tuner and better person.
What gas are you using?
Here's some tips about using the SCT tuner if you want them:
1. Buy a trickle charger (3amp )and use this when changing tune. SCT has an issue with 2011+ 5.0's. It's a voltage issue and trickle charger is great insurance.
2. Always change the tune at your house.
3. Make sure your Auto Lamps are off. (I learned the hard way)
Thanks,
Steve
2013 Boss 302 PW, Recaro, Torsen, AED tune, Airaid CAI, MGW, Hotchkis Springs/LCA, Whiteline Relo, CHE K Member w/Torque Limiters, Griggs Torque Arm Kit, T/A rear girdle, Kenny Brown Pan Hard Bar, Whiteline Tranny Bushing, JPC Linelock, JPC stainless clutch line, MT ET Street Radials (when needed), , 2013 GT500 Quad Axle Backs, Kooks LT 1 3/4, O/R X Pipe, Resonator Delete, JPC Line Lock,JPC Clutch Line.
03-07-2014, 03:23 PM
Thanks,
Steve
Care to expand on these? What are the issues that come up when using a SCT?
03-07-2014, 03:52 PM
I decided to change my tune at the drag strip and I "bricked" the car. Would not load the tune or recover my stock tune. We disconnected the battery for 20 min. and finally able to load the tune.
If I remember correctly; got a "charging system" error. It was at night and I forgot that I had the "auto lamps" on !!!!
I called SCT and spoke to one of the dealer rep technicians. He admitted that there was a problem with the 2011+ 5.0 in the voltage system. A random issue with a voltage surge and they were working on a fix. Still haven't heard about a fix.
His recommendation was the same as Shaun's: Get a Trickle Charger and use this when changing the tune. Never change the tune away from home. All accessories "off" , including "auto lamp".
I purchased a trickle charger from Auto Zone. Actually, I couldn't find a 2 Amp; only a variable (Schumacher 2-10 amp, which works great).
Works great and have not had an issue with loading a tune since.
Hope this helps.
03-07-2014, 04:13 PM
Check this thread. http://dfw50s.com/showthread.php?t=2630
Basically the SCT handheld demands a lot of voltage from the car's ECU. If you have too much electrical demand on the car's charging system without the alternator to recharge it, the ECU essentially shuts itself down to protect from electrical surge.
03-07-2014, 04:36 PM
Good info, glad I learned about it before hand! Thanks guys
03-07-2014, 04:45 PM
I wish I would have been a member here when I first tuned my car.
Great post and excellent description of the problem and fix.
I'll be sure to refer others to this in the future.
03-07-2014, 06:11 PM
No problem. Just glad I could save you from a potential headache.
Thanks. This issue popped up a lot on SVTP, so I decided to finally type something up.
You don't always need a trickle charger, however. Just roll both windows down, and turn off all accessories (lights, radio, HVAC, etc) and keep all doors, trunks, and hoods closed. You should still be able to tune the car that way.
03-07-2014, 08:11 PM
Dang I didn't have an issue at all. I will make sure in the future to do these things just to make sure. Thanks for the heads up.
Also, I only run 93 gas.
2011 Kona Blue 5.0
03-10-2014, 10:17 PM
#13
can anyone verify the need of a charger when tuning with an sct itsx? Or is it a handheld only issue?
2013 Mustang GT/CS | Borla S-Type AB | Wincos Tint | Shorty Antenna | Redline Hood Struts | Eibach Pro Kit Springs | Koni STR.T Shocks/Struts | GT500 Strut Mounts | Eibach Camber Bolts | BMR ADJ Panhard Bar | BMR ADJ UCA | BMR UCA Mount
03-11-2014, 12:06 AM
#14
Issues with the iTSX are typically having the Bluetooth signal lost middle of the tune.
03-11-2014, 12:07 AM
#15
Lovely!
