Old 03-18-2014, 04:29 PM   #1
Shiftybusiness
Default What should I do about strut mounts
My current setup is Eibach Sportlines, BMR adjustable panhard bar and stock struts and shocks. I want to go with Koni yellows and catch the sale going right now. My question is do I get the 05-10 Koni's and GT500 strut mounts or the 11-14 Koni's and stock mounts? Are the GT500 mounts that much better?
Shiftybusiness is offline   Reply With Quote
Old 03-18-2014, 04:42 PM   #2
Get the 05-10 and get GT500 mounts. The factory mounts, although can be reused, are really more of a one time use part. The GT500 mount is a little more robust.
Or just spend the extra money on caster/camber plates.
Old 03-18-2014, 11:57 PM   #3
JDMLOL
JDMLOL's Avatar
My sportlines were too low to adjust the front end, even with camber bolts. Get camber plates and the shocks for 11+
Old 03-19-2014, 08:35 AM   #4
Shiftybusiness
Not what I wanted to hear lol. Thanks for the information.
Old 03-19-2014, 09:15 AM   #5
You can try turning the GT500 mounts inward to gain more camber adjustment. Basically install them with the "arrows" pointing in. It's a common trick used by a lot of people.
Old 03-19-2014, 12:30 PM   #6
cmanley99
If you can afford it, get the camber plates. It's costly but makes it all easier.
2012 Mustang GT Automatic Grabber Blue
Air Raid CAI, BBR Off Road X-Pipe, GT500 mufflers,
3.73 gears, Kevin Dunn Tune
cmanley99 is offline   Reply With Quote
Old 03-19-2014, 01:33 PM   #7
El_Tortuga
El_Tortuga's Avatar
If you are going to autocross or track I'd get the camber plates. The maximum motorsports ones come with bushings so they are compatible with either style strut.
Old 03-19-2014, 02:11 PM   #8
Shiftybusiness
That's probably what I will do, buy the struts and shocks then save up for the plates.
Old 03-19-2014, 06:33 PM   #9
Hddcrasher
As long as you are saving up for strut mounts , you should have a look at the Vorshlag CC Plate offering. If you plan to Auto cross then these are worth the price. "IMO"
2012 Kona 5.0 Premium Auto.
Vorshlag Mods:
Brembo Brake kit, CS lower valance with brake cooling kit, Bilstein dampers & springs with Vorshlag CCplates. Custom CS lower grill mesh.
Hddcrasher is offline   Reply With Quote
Old 05-01-2014, 07:49 PM   #10
Dan12GT
Dan12GT's Avatar
Not sure what drop the springs will net you but I recently put my SRT.T shocks / struts on with the GT500 mounts and its great! If you need more adjustablility due to the drop (if its low) then go with the 11+ shocks / struts and pair them with a caster / camber plate. I Didn't need the extra adjustability and am in perfect spec with the GT500 mounts, 05-10 SRT.Ts, and BMR springs.
Old 05-01-2014, 09:43 PM   #11
Shiftybusiness
I ended up going with gt500 strut mounts and koni yellows, I already have Eibach sportlines on the car. I haven't installed the strut mounts, struts, and shocks yet. Hopefully in the next week or two I'll have time to do it. I'm gonna try the arrows in on the strut mounts but if I need caster camber plates I will just have to bite the bullet and get some.
Old 05-02-2014, 12:51 AM   #12
You would be fine with just some eibach camber bolts. That's what I had for a long while. I just went to cc plates for the adjustability at the track
Old 05-02-2014, 09:07 AM   #13
Shiftybusiness
Cool, that's good to know. I'll probably get some cc plates in the future right now there are other things I'd like to do first. Do you still have you're Eibach camber bolts? If you do and still want to sell them I'll buy them from you.
Old 05-02-2014, 01:49 PM   #14
Yea I do. Pm me
Old 06-06-2014, 01:02 AM   #15
NAVAG
NAVAG's Avatar
Factory Strut Mounts are garbage and only lasted a couple of months after lowering the car. I just installed Orange Koni's and GT500 Upper Strut Mounts to get rid of the popping noise.
The noise is gone and it feels like it rides a little smoother. Only problem is that the GT500 Strut Mounts don't fit on the 2011-2014 Struts so I had to buy 2005-2010 Struts to make them work. Going to Muffler King tomorrow to get it aligned again.
NAVAG is offline   Reply With Quote
