Old 04-19-2014, 09:34 AM   #1
donutninja
donutninja's Avatar
Default Pinion Angle Adjustment
The car's been lowered for little over a month but I still need to get the pinion angle adjusted especially since it's a pretty dramatic drop.
I've been calling around but no shops will touch it. (Firestone, NTB, local garages) Is it crazy to call up Ford and see if they'll adjust it since the car is still under warranty? Or do ya'll know of any shops in the Carrolton/Coppell area that can adjust the pinion?
It drives fine but I'm hesitant to drive it harshly until this is adjusted.
Also, I did a forum search and didn't really come up with much and not sure if this is in the right sub-forum. It's sorta suspension related.
thanks!
donutninja is offline   Reply With Quote
Old 04-19-2014, 09:42 AM   #2
KurvStr8nr
KurvStr8nr's Avatar
Vorshlag in Plano can handle this for you.
| 2013 GT Prem | Ingot Silver | Track Pack | 6MT | 3.73 | Torsen | Recaros | Boss Diffuser |
| BMR SP009 Springs | BMR LCA Relo | Whiteline PHB | CS Pedestal Spoiler | LeMans Stripes (Big Worm Graphix) |
Coming soon: | MGW 2014 MT-82 Shifter |
KurvStr8nr is offline   Reply With Quote
Old 04-19-2014, 09:51 AM   #3
donutninja
donutninja's Avatar
Yeah, I was looking for somethig closer :/
If not, I'll definitely hit them up. I know they know what they're doing .
Old 04-19-2014, 10:41 AM   #4
JDMLOL
JDMLOL's Avatar
You have an adjustable Uca, right? If you're closer to ft worth hit up darkhelmet22 on the board. He's a tech at a reputable dealership. That's who did my driveshaft and pinion angle.
Old 04-19-2014, 01:03 PM   #5
rlhay2
rlhay2's Avatar
It's not hard to do. Just need the proper equipment. Any performance shop should be able to knock it out easily.
07 TT GT500 w/misc supporting mods
rlhay2 is offline   Reply With Quote
Old 04-21-2014, 10:20 AM   #6
hatchttu
hatchttu's Avatar
On the fb page someone posted about a place called Darryl's Premium AutoCare & Performance doing their pinion angle. says the guy who did it owns a 12 boss too.
hatchttu is offline   Reply With Quote
Old 04-21-2014, 11:12 AM   #7
donutninja
donutninja's Avatar
Thanks guys!
Old 04-21-2014, 11:49 AM   #8
Dominic Toretto
Dominic Toretto's Avatar
How much did you lower the car?
Old 04-21-2014, 12:29 PM   #9
donutninja
donutninja's Avatar
At least 2"
I called Vorshlag and made an appointment.
Old 04-21-2014, 12:33 PM   #10
Dominic Toretto
Originally Posted by donutninja View Post
At least 2"
Is it just recommended to do it, or did you actually notice a difference during hard acceleration?
Old 04-21-2014, 01:10 PM   #11
rlhay2
rlhay2's Avatar
My car is a bit of an exception but with a 0* to -1* pinion angle, it would spin the tires any time you were under 90mph. With a -2* pinion angle it hooks all boost levels.
Old 04-21-2014, 03:42 PM   #12
Toby
With anything but heim joints you may set the angle at say -1, but during hard acceleration with say urethane bushings, you may end up around +1- +3 due to deflection in the bushings. And lets not get started with rubber bushing deflection..
Its all about the setup.
Old 04-21-2014, 12:40 PM   #13
donutninja
donutninja's Avatar
I don't notice a difference or anything. I just know it isn't good for wear and tear on the car. It's my daily so it gets a lot of mileage.
Old 04-21-2014, 01:02 PM   #14
JDMLOL
JDMLOL's Avatar
The heavy factory shaft or any cv shaft will cover up a lot of the obvious signs that the p/a is off.
